AlcatelUnleashed migrated to a new server. Expect some latency for 72hrs
Virtual 7750 SR Available in 12.0.R4
rifster
Re: Virtual 7750 SR Available in 12.0.R4
Post by rifster »
+gutsy81 wrote:You mean sudo nano link12.xml is feasible if link12.xml has not been defined or does not exist before, as you stated below?
Yes. First you create the bridge file and then go to virsh and define it (point 4.3)
Stoffen
Post by Stoffen »
rifster wrote: Yesterday I experimented a bit with new GNS and managed to connect Juniper olive, Cisco IOS (on dynamips) and ALU vSR, all in star topology connected together by Cisco IOU switch. If you have powerful PC you can do basically any multi-vendor topology you want right now.
For IOU setup I recommend following link:
http://www.routereflector.com/2014/04/i ... y-release/
To get IOU speaking to the rest you also need to change the gns3server IP binding from 127.0.0.1. I picked my LAN IP.
I will try to create a larger multivendor topology with at least Cisco and ALU.
Also nice to test multicast topologies as Cisco routers can join multicast from CLI.
Havent found any similar way to do this in the SROS.
But I'm struggeling.
I can drag and drop vSR's and boot them, but I'm not getting any sort of connectivity between the devices.
What have I missed here?
I have tried to connect all 6 interfaces (CPM -> 1/1/5) no connectivity at all. :shock:
I am using 6 E1000 NIC's on the QEMU VM, and thats about all settings I can provide.
Did your devices interconnect out-of-the-box?
EDIT;
After I saved the project from the start, I get IP connectivity.
Time to set my laptop on a serious cpu and memory test :)
NextStep will be to install GNS3 in the CentOS environment to do the same type of setup there.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
rifster
Post by rifster »
Stoffen wrote:Did your devices interconnect out-of-the-box?
Yes. I did not save the project for the multi-vendor topology I mentioned before.
Stoffen wrote:NextStep will be to install GNS3 in the CentOS environment to do the same type of setup there.
Good luck! :)
Stoffen
Post by Stoffen »
rifster wrote: Good luck! :)
Thanks!
Btw, how did you store the configuration for the vSR's?
Mine is not stored in the disk-image under \projects\<projectname>\qemu\vm-x\hda_disk.qcow2
This file is not updated with admin save or GNS3 save.
I tried to export configs, but only IOS configs are exported.
Reloading the vSR from CLI;
Executed 170 lines in 0.8 seconds from file cf3:\config.cfg
Reloading the vSR via shutdown on the VM;
Executed 0 lines in 0.0 seconds from file cf3:\config.cfg
Any tips?
[flash=]
Christoffer
Nokia SRA #265
LinkedIN
[/flash]
rifster
Post by rifster »
Stoffen wrote: Btw, how did you store the configuration for the vSR's?
Checked on Win7 and Xubuntu and for some reason config save works on Linux and doesn't on Windows. No idea why...
caominhthuy
Post by caominhthuy »
someone has file SR-OS.TiMOS-SR-12.0.R4-vm.zip, plz share it for me :)
Stoffen
Post by Stoffen »
Perhaps you could shoot a question as a possible bug on gns3 community?
I dont have a running Ubuntu environment, and my CentOS environment is a bit tricky to get GNS3 running.
--Christoffer
[flash=]
Christoffer
Nokia SRA #265
LinkedIN
[/flash]
Stoffen
Post by Stoffen »
caominhthuy wrote:someone has file SR-OS.TiMOS-SR-12.0.R4-vm.zip, plz share it for me :)
You can download it on www.alcatel-lucent.com
[flash=]
Christoffer
Nokia SRA #265
LinkedIN
[/flash]
ciscovoz200
Post by ciscovoz200 »
Hi!
can you provide the information where to find this image on ALU web site, what page?
What kind of login do i need? Is general access enough?
I will really appreciate if you share it any means anyway...
rifster
Post by rifster »
ciscovoz200 wrote:can you provide the information where to find this image on ALU web site, what page?
This link will take you directly to Product Download page:
https://download-emea.support.alcatel-l ... r_id=76472
Of course it's available only for registered users but I'm not sure what type of access is required.
Return to “7750 SR”
