AlcatelUnleashed migrated to a new server. Expect some latency for 72hrs
Virtual 7750 SR Available in 12.0.R4
EdHunter
Re: Virtual 7750 SR Available in 12.0.R4
Post by EdHunter »
Hi Stoffen,
I'm running TiMOS-B-13.0.R6 and yes indeed that's the problem.
I had same MAC addresses under the interfaces although i used different ports (vSIM1 1/1/1 ---- vSIM2 1/1/3).
I managed to ping the interfaces from one side to another and works like a charm now.
Thanks for your time.
Cheers
Ed
Stoffen
Post by Stoffen »
Just for show; 7750 SR-1 running SROS 16 in GNS3:
System Information
System Name : SR07
System Type : 7750 SR-1
Chassis Topology : Standalone
System Version : B-16.0.R5
GNS3 additional options:
-nographic -enable-kvm -uuid <uuid> -smbios type=1,product="TIMOS:slot=A chassis=SR-1 card=iom-1 mda/1=me6-100gb-qsfp28 system-base-mac=e4:ed:17:00:00:00"
A:SR07# show card state
Card State
Slot/ Provisioned Type Admin Operational Num Num Comments
Id Equipped Type (if different) State State Ports MDA
1 iom-1:he up up 2
1/1 me6-100gb-qsfp28 up up 6
A cpm-1 up up Active
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
a1x0
Post by a1x0 »
Hello!
Can anyone share TiMOS-SR-12.0.R4-vm.qcow2 image?
landrym
Post by landrym »
Appreciate these links are ~6 years old now but really interested in obtaining TiMOS-SR-12.0.R4-vm.zip and other images for use with EVE-NG for study purposes. Some links are no longer available, some take me to the Nokia website where I have registered but have no rights to access software downloads. I'm a legacy Omniswitch R6/R7 ACSE looking to study ALU service routers. Any help would be appreciated.
rahul1603
Post by rahul1603 »
Hi All,
I have gone through almost all of the pages of this post. But still I am not able to get the 7750 VM up and running on a KVM box (ubuntu 16.04). The Graphical console is stuck at booting, whereas the serial console does not proceed after the below given output. I have nested virtualization enabled on the ubuntu host machine.
Any help would be highly appreciated.
I have tried 2 image versions viz. TiMOS-SR-12.0.R6-vm and sros-vsim-14.0R6.qcow2. but none of them have worked. I have attched the dump of the virsh file below and this is the max output I get on serial console --
root@haxbp22:~# telnet 127.0.0.1 4560
Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '^]'.
(s) boot params: pl=1; setting TgtPf to 0x00000001
ACPI: ctrl-x only supported with PXE boot. (version >= 3)
Enabled core count: 2
emGetMacAddr: unit 0 is not VALID
Running in a KVM/QEMU virtual machine
Stoffen
Post by Stoffen »
Hi Rahul.
The boot sequence seems correct.
Does nothing happen after the
Do you run an Intel CPU? I've read somewhere that AMD CPU does not work, but never tried myself.
It should continue to boot, or at least give you some error message in the serial console window.
However, it seems you have not defined any Timos settings in your XML.
Try to add the following to your XML:
<domain type='kvm'>
  <name>vSR1</name>
  <uuid>your-uuid-string-here</uuid>
  <memory unit='KiB'>4194304</memory>
  <currentMemory unit='KiB'>4194304</currentMemory>
  <vcpu placement='static'>2</vcpu>
  <sysinfo type='smbios'>
    <system>
      <entry name='product'>TIMOS:address=10.0.0.2/24@active slot=A chassis=SR-a4 card=cpm-a</entry>
    </system>
  </sysinfo>
  <os>
    <type arch='x86_64' machine='rhel6.6.0'>hvm</type>
    <boot dev='hd'/>
    <smbios mode='sysinfo'/>
  </os>
This should give you a SR-a4 with no MDA.
You can modify the chassis and cards to match something supported by your image.
For single VM, go for the SR-c4/c12 chassis on older software, or SR-1 SR-1s in more recent software.
[flash=]
Christoffer
Nokia SRA #265
LinkedIN
[/flash]
Lala
Alcatel 7750 12.0.R6 in GNS3
Post by Lala »
Hi All,
Can anyone help me out.
I am running Alcatel 7750 12.0.R6 inside GNS3 , VM turning on & getting console to,
However could not run command show card state
A:vRR# show card state
Error: Invalid parameter.
A:vRR# show system license
Current License
License status : card reboot pending, missing license record
Time remaining : CPM A will reboot in 50 minutes
License name :
License uuid :
Machine uuid : 95ff27f1-ea41-4ea1-bc47-35e43d5aad72
License desc :
License prod :
License sros :
Current date : SUN OCT 17 18:29:48 UTC 2021
Issue date : n/a
Start date : n/a
End date : n/a
A:vRR#
Stoffen
Post by Stoffen »
Hi.
If I'm remembering correct, the 12.0 was vRR only.
However, it seems that the one you have booted requires license to be able to do anything.
If you don't have a license, I would recommend using SROS 13.0.
13.0 is fully functional without license, but reboots every 60 minutes.
[flash=]
Christoffer
Nokia SRA #265
LinkedIN
[/flash]
Return to “7750 SR”
