We support GIXEN, the eBay sniper.
Best Buy Co, Inc.
Changing the location in Pimphony
Avi1
Post by Avi1 » 27 Jun 2007 07:31
Hi guys,
Is it possible to change the dialing parameters in pimphony when it is startet without restart of pimphony ?
I have two or more dialing prefixes defined in my Oxo, one for normal telephony (e.g."0") and the other (e.g. "9") for my GSM-Gateway. The problem is, when i change the location in Pimphony under "options", i need to restart the application to take effect. Since pimphony needs more than 3 minutes to get loaded, this is not a good solution.
I wrote a program, which changes the default location unter windows, but pimphony still needs to be restartet to apply this change.
Does anyone know a registry entry where pimphony gets exactly this information or is it loaded into the memory when its startet ?
steg81_DUP
Re: Changing the location in Pimphony
Post by steg81_DUP » 02 Jul 2007 02:08
It is loaded into the memory when pimphony is started, however if you just select no dialing "0" then you manually type this yourself when making a call much eaiser.
I wouldn't mind getting my hands on that program that changes windows location, would you be kind enough to share it?
Stay Cool!!!
Return to “Applications”
Who is online
Users browsing this forum: No registered users and 1 guest
