how to register other DECT handsets?
Everything about the PWT, IBS, RBS, DECT..
junpeng
Post by junpeng » 20 Sep 2008 09:34
Many of my company's mobile 100 has worn out and since Alcatel doesn't provide mobile 100/200 any longer, I want to use some other DECT phones. From here I know Siemens S45 or E45 can do the job well. But I don't know how to register these DECT phones. After reading Siemens gigaset S45 manual, I find S45 can register to at most 4 bases, and it needs base PIN and base number during the registration procedure. When registering a mobile 100, I choose "N" when asked which base to register, then it registers to all the base stations. By using dectarea, I found there are 16 base stations in my company. So, what should I do after choose GAP handset type and run dectinston -g command, how do I deal with these base number and base PIN issue. By the way, I have tried to register the mobile 100 in GAP mode, its procedure is just like the GAP+ mode, no need of base number and base PIN.
junpeng
Re: how to register other DECT handsets?
Post by junpeng » 20 Sep 2008 09:42
Any other DECT handsets and their registration procedures are welcome
Post by vad » 21 Sep 2008 02:02
Create sets with GAP type.
Use dectinston Dir_number or dectinston -g command.
On GAP handset start registration procedure.
When you see on GAP handset Base1, 2 .. - this is not base (individual IBS or RBS)- this is system (like for mobile 100/200). You can register in Base1 f.e. on your PBX, Base2 f.e. at home and so on.
bouncer_ie
Post by bouncer_ie » 21 Sep 2008 07:44
would recommend kirk hansets as an alternative
http://www.kirktelecom.com/company/suk90.asp
junpeng
Post by junpeng » 24 Sep 2008 21:54
vad wrote:Create sets with GAP type.
What about the PIN? I can't register S45 because it has no response. Is it the reason of the PIN. When asked to input PIN, I just input OK to use the default 0000. Or it is due to the weak signal, but I can easily register a Mobile 100 in GAP mode.
Post by vad » 24 Sep 2008 23:22
Usually when GAP set ask PIN you need to dial 0000 and OK (for Siemens).
Return to “Wireless configuration and sets”
