I can't find in ALE Portal documentations about procedure of migration from Advanced Communications Server 9.1.0b6586 to OpenTouch Media Services 2.3.
Can you help with the documentation? Thanks.
Migration steps from ACS 9.1.0b6586 to OTMS 2.3
Re: Migration steps from ACS 9.1.0b6586 to OTMS 2.3
As far as I know there is no Migration path. New install OT and reconfigure.
And I can't use any backup to restore data from ACS?
- cavagnaro
Nope, DBs are completely different
Ok, thank you for answers
You are absolutely right. I have installed from scratch.
