Multicast Configuration
Jarrueb
Post by Jarrueb »
I need to create a multicast network. I have 6450,6350,6850.
This is my network :
Stream Server ----> 6450 <---------> 6350 <---------->6850<-------->6450<--------Users
I have an IP address on VLAN 10 on all switchs for Mangement.
I used VLAN 70 between Stream server and Users. Stream server send to ip : 225.0.0.1 to 225.0.0.8
Which is the best configuration on my switchs? IP address for all swichs on Vlan70 ?
Which is "querier-forwarding","querying" ? I need to use "Proxying", "Spoofing", "Zapping"?
I'm lost .... :?
Thank you for your help
Re: Multicast Configuration
If MC streamer and clients in same vlan, than you don't need MC routing (PIM, DVMRP) - you only need MC-switching.
At all your switches you have to enable MC:
ip multicast status enable
for MC you need at least an one switch an ip interface in this vlan (mostly your core, 6850???). This device is the querier - so this command is necessary there:
ip multicast querying enable
And if the streamer is not attached to the querier you need at this switch and all switches to the querier (6350/6450) the querier forwarder:
ip multicast querier-forwarding enable
But you can also activate all the three command at all your switches. There will be no problem with this.
Jarrueb
Post by Jarrueb »
Thanks you Silvio,
It's working !!! :)
We can see MC with commands :
show multicast group
show multicast forward
skigno
Post by skigno »
Hi all,
i want to understand better this post.
On the same switch if i have the MC Stream on VLAN 10 and users on VLAN 20, i must enter some commands for enable MC between vlans like:
ip multicast vlan 10 status enable
ip multicast vlan 20 status enable
Then if i have a situation like this:
Stream Server <---------> 6450 <---------> CORE <----------OSPF--------> CORE <---------> 6450 <--------->Users
what is the correct configuration considering the vlans are different between sites.
Thanks.
Multicast switching (IPMS) is L2 (within same vlan), Multicast Routing (IPMR) is L3 (between different vlan).
6450 does only support IPMS, but all the R7/R8-Switches with the advanced licens support also IPMR.
There are different IPMR-protocolls: DVMRP, PIM-SM, PIM-DM
Together with OSPF you can use PIM. In your case I would suggest PIM-DM (dense mode) - at your cores at all IP-Interfaces with MC-Traffic.
alt4u
Post by alt4u »
Hi Silvio,
Current scenario in VLAN 30
Stream Server <---------> 6450 <---------> OS6850E-U24X (CORE Switch) <---------> 6450 (MultiFloor) <--------->Users
how do I include another multicast stream on the same route but in different VLAN 40 for temporary migration and the dhcp IP address is same for both VLANs from the middle ware application.
Do I need interface IP in atleast one of the switches in vlan 40 ?? This can't be done as third party middleware application is providing dhcp ips to all end users in both VLANs.
Or do I need to enable IPMS in specified VLANs seperately ??
Core Switch IPMS:
ip multicast spoofing enable
ip multicast zapping enable
ip multicast proxying enable
ip multicast flood-unknown enable
On 6450 attached to Stream Server:
this command is necessary at the switch with an ip interface in the vlan. I assume this is the core.
thekotaksampah
Post by thekotaksampah »
Hi guys,
If the ethernet-service sap, which is one of the VLAN and SVLAN require carry IGMP traffic. is the command mentioned earlier can work with metro-e configuration?
Technical Blog: ngoprek.achyarnurandi.id
Return to “OmniSwitch 6450”
