While implementing zmodem,os6900 default language changed
ramandeep
Post by ramandeep »
As i am implementing zmodem procedure,
setenv baudrate 115200
saveenv
boot
then i restored it back to 9600
Meanwhile i rebooted the switch 6-7 times and its default language changed.
Please help me to change it back to english.
Re: While implementing zmodem,os6900 default language changed
this isn't a different language - the reason is the wrong baudrate. Change the baudrade at your PC to all possible entries (9600....115000). One will be the correct one and you will see all fine
ramandeep
Post by ramandeep »
Dear Silvio,
I have tried all possible entries in my PC but not successful. I am able to write the commands in 9600 baud rate in miniboot in different language.
English language is not displaying.
reboot the switch, take other PC.....
=> printenv output of all settings
and .... setenv *** to change settings
ramandeep
Post by ramandeep »
Dear Silvio,
There is issue with Teraterm terminal. After pressing "Reset Terminal/reset port" English language is displayed.
Thanks for your support.
thanks for sharing the solution.
Return to “OmniSwitch 6900”
