Hello to all members,
Please can someone tell me if there is a possible way to save a configuration on an alcatel 7750 running on a gns3? I have to say that the timos has NO license so it boots every 60 minutes.
Thanks in advance
7750 SAVE IN GNS3
Re: 7750 SAVE IN GNS3
\admin save should do the trick.
I do expect you to run the 7750 VM in GNS3-VM.
I had issues saving config previously when using windows qemu engine.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
Christoffer
Nokia SRA #265
[/flash]
It didnt work with admin save
Of cource i raun the 7750vm in gns3 vm!
Any other solution please???
admin save works all the time in my GNS3 environment.
Do you see any error messages when running admin save?
Is the configuration actually stored in CF3?
\file type cf3:/config.cfg
Ensure you question the correct file.
When booting, what info do you get from console output when it reads your config file?
From my SR:
Executed 264 lines in 0.2 seconds from file cf3:\config.cfg
From my SR:
A:SR01# \file type cf3:/config.cfg
File: config.cfg
# TiMOS-C-15.0.R7 cpm/x86_64 Nokia 7750 SR Copyright (c) 2000-2018 Nokia.
# All rights reserved. All use subject to applicable license agreements.
# Built on Wed Jan 10 15:24:09 PST 2018 by builder in /builds/150B/R7/panos/main
# Generated WED OCT 03 13:32:24 2018 UTC
exit all
configure
echo "System Configuration"
system
name "SR01"
time
A:SR01# admin save
Writing configuration to cf3:\config.cfg
Saving configuration ... OK
Completed.
A:SR01#
[flash=]
Christoffer
Nokia SRA #265
LinkedIN
[/flash]
Christoffer
Nokia SRA #265
[/flash]
