SCP in CLI script
kave_dish
SCP in CLI script
Post by kave_dish »
I'm trying to use a CLI script to export a file via SCP. The script uses the scp command, and then enters the password when prompted. It contains lines akin to:
scp filename.dat user@location
mypassword
However, since the password prompt isn't the standard user prompt (it's literally just "Password:", instead of "devicename#"), the script won't drop in the "mypassword" line. Is there any way to get this working?
sadim
Re: SCP in CLI script
Post by sadim »
try: sshpass -p "mypassword" scp filename.dat user@location
kave_dish
Post by kave_dish »
sadim wrote:Hi,
Thanks for the reply. No luck. It didn't recognize the sshpass command. Here's the failure message:
CLI command "sshpass -p "mypassword" filename.dat user@location" failed. CLI output is Last result:Error: Bad command.
kave_dish
Post by kave_dish »
I should clarify - I'm running these commands on a 7750s.
Return to “5620 SAM”
