licence for 10 DECT-need update of release?
kabersystem
Post by kabersystem »
I need more licence for dect users( I have ten and need more 10).Do I need to make release update and CPU replacement to get these 10 licence? The release I have is 7.x<8.The licence for dect is :3EH03099AA
Thank you
enio.eltz
Re: licence for 10 DECT-need update of release?
Post by enio.eltz »
I think so, ask to you VAD. In our case, in Brazil, I can not buy licenses for release 7 or previous anymore, it is necessary to upgrade to the latest.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
kabersystem
Our provider told us that we need a new release and a cpu, but I don't know if I should believe it .He told me the same thing with our new phone 8039, but it worked without cpu or a new release
enio.eltz
Post by enio.eltz »
8039 works in compatibility mode in previous releases than R9, in OMC you should see it as 4039. So, for new DECT licenses, new release and the powerful pwCPU EE.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
The background issue is Alcatel providing support for new base without proper software updated on your side. Technically you could just add the license, commercially, Alcatel won't allow it because support.
Return to “DECT”
