8460 ACS web admin
prasad0777
8460 ACS web admin
Post by prasad0777 »
hi ...
My ACS server successfully installed but I can't connect to the server through web admin. even I can not do ping to ACS server IP Address. do have to do any other configuration make this work
ACFE OXE R 10
ACFE ICS R 6.5
ACPS OpenTouch
ACPS Data
Put a laptop on that port, put ACS Ip address to that laptop, can you ping it? I bet it is a network issue.
prasad0777
hi ..
When the laptop connect to the same patch cord with same IP. PING is working.
ACFE OXE R 10
ACFE ICS R 6.5
ACPS OpenTouch
ACPS Data
Put the cable now between your laptop and the TW server, run a sniffer and he what traffic you get. Normally you install TW and configure the IP address and that is it...
prasad0777
thanks .... the problem was Lan card was not compatible with Red Hat. I installed it to HP ML 150 and problem was fixed. but I have new problem. if you can please help. When I try to upload teamwork licence file it says wrong licence. this is same licence I use when I was in ICS training. my question is teamwork licence is also bond with mac address of the PC like ICS licence. is their any way where I can use my demo key for my lab.
ACFE OXE R 10
ACFE ICS R 6.5
ACPS OpenTouch
ACPS Data
No way hehe
Ask ALU for a new license
banfield
Post by banfield »
prasad0777 wrote:thanks .... the problem was Lan card was not compatible with Red Hat. I installed it to HP ML 150 and problem was fixed. but I have new problem. if you can please help. When I try to upload teamwork licence file it says wrong licence. this is same licence I use when I was in ICS training. my question is teamwork licence is also bond with mac address of the PC like ICS licence. is their any way where I can use my demo key for my lab.
Rehost the demo licens at BP
Return to “OmniTouch 8460 Advanced Communication Server”
