Tomcat / Java looking for wrong server
server was changed in fax web admin screen
How do can I change it
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.net.UnknownHostException: csddc01.csd.centennialsd.org
jcifs.UniAddress.getAllByName(UniAddress.java:315)
jcifs.UniAddress.getByName(UniAddress.java:245)
jcifs.http.NtlmHttpFilter.negotiate(NtlmHttpFilter.java:156)
jcifs.http.NtlmHttpFilter.doFilter(NtlmHttpFilter.java:114)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.23 logs.
TomCat error cause DC change
- cavagnaro
Re: TomCat error cause DC change
Reinstall
Enviado de meu C6602 usando Tapatalk
we got that issue fixed thanks you... We are now having a second issue... From Outlook faxing okay. from Gui interface we are getting the following error
HTTP Status 500 - -------------------------------------------------------------------------------- type Exception report message description The server encountered an internal error () that prevented it from fulfilling this request. exception jcifs.smb.SmbException: jcifs.util.transport.TransportException java.net.SocketException: Connection reset at java.net.SocketInputStream.read(Unknown Source) at jcifs.util.transport.Transport.readn(Transport.java:29) at jcifs.smb.SmbTransport.peekKey(SmbTransport.java:355) at jcifs.smb.SmbTransport.negotiate(SmbTransport.java:268) at jcifs.smb.SmbTransport.doConnect(SmbTransport.java:299) at jcifs.util.transport.Transport.run(Transport.java:240) at java.lang.Thread.run(Unknown Source) at jcifs.util.transport.Transport.run(Transport.java:256) at java.lang.Thread.run(Unknown Source) jcifs.smb.SmbTransport.connect(SmbTransport.java:289) jcifs.smb.SmbSession.getChallenge(SmbSession.java:146) jcifs.smb.SmbSession.getChallenge(SmbSession.java:140) jcifs.http.NtlmHttpFilter.negotiate(NtlmHttpFilter.java:157) jcifs.http.NtlmHttpFilter.doFilter(NtlmHttpFilter.java:114) note The full stack trace of the root cause is available in the Apache Tomcat/5.5.23 logs. -------------------------------------------------------------------------------- Apache Tomcat/5.5.23
- cavagnaro
Well good luck. You changed something only you know what. Now you have a 500 error...which as indicates you must check logs.
We have no magic balls available for now
Thank you for all your help can I ask two more questions
The only thing changed was under Domain controller
we had to change it to ad-dc1.csd.centennialsd.org
the old domain controller is off line it was csddc01.csd.cenrennialsd.org
can we user an IP address instead of a FQDN
Where can I find Apache Tomcat/5.5.23 logs
- cavagnaro
I know the "only" thing that changed was the name, but you have to know that Tomcat installed modifies internal files according to that name. That is why I suggested a clean reinstall with new name.
You must use FQDN because is a requirement. Also in that way you can change IP address with out these issues.
Reinstall will be the fastest method. Takes nothing. Make a user backup only.
