TSAPI client issue on nice
Xero
Post by Xero »
After the release migration from OXE 6.1 to OXE 9.1 we are able to connect the TSAPI client to appliance servers, but there are no incidents shown on the TSAPI client for any kind of event performed for instance if the agent on-hook, off-hook, dials a number, called duration of the call, or even the agent id or the set number are not shown in the events.
krzysioD
Re: TSAPI client issue on nice
Post by krzysioD »
any logs? tsapi client connects to a tsapi server, what does a csta_mono page on oxe @ip say? your tsapi server connects to a OXE?
iirc: after oxe upgrade it is advised to upgrade tsapi server to, as for example the private_data filed was expanded, and simply old tsapi with new OXE are NOT compatible.
Compability matrix could be found on tsapi CDROM :)
Xero
Post by Xero »
TSAPI server is already upgraded to 6.4.7, and csta_mono page says that OXE connected to TSAPI but still no events logged
Return to “TSAPI”
