SoftPanel - Please read !
Post by frank » 27 Jul 2009 11:14
Last update: 2014.02.04
SoftPanel demo is available at
http://softpanel.edemo.biz:8080/wbm/
Login : demo – Password : demo
A system restoration is done every day.
if you have any question about this product, email edemo-support@proserv.alcatel.com
jlebleu
Re: SoftPanel - Please read !
Post by jlebleu » 27 Oct 2009 10:23
[flash=]URL has changed[/flash]
Here are softpanel demo files :
http://softpanel.edemo.biz:8080/flashdemo/
Doc is here :
http://softpanel.edemo.biz:8080/wbm/Sof ... tation.pdf
Release notes are here :
http://softpanel.edemo.biz:8080/wbm/releasenotes.txt
And a demo version :
http://softpanel.edemo.biz:8080/wbm/ user : demo password : demo
Reinoud
Post by Reinoud » 15 Apr 2011 11:12
these links do not work anymore, do you have alternatives?
Post by cavagnaro » 01 Jun 2011 11:10
Any new links? I also would like to see more details for this
krzysioD
Post by krzysioD » 01 Jun 2011 16:02
RTI developer is on the run, or to be more precise he is being movement from one place to another place, expect this update after end of week 25/26 IIRC.
Post by frank » 03 Feb 2014 09:30
Wow.. I am soooo late on this topic.
I just looked at it and realized no links are working like you guys said.
I will try to track down the guys who take care of the softpanel, and see if there is any new link I can get.
krzysioD
Post by krzysioD » 03 Feb 2014 10:26
Well, without Jlebleu it's not the same product nor support anymore.
Post by frank » 04 Feb 2014 11:18
I just found out. The new URL is updated.
Return to “Call Center SoftPanel (ALU ProServices)”
