ccd pilot number cannot be called by internal user.
nyt88888
hi,
how do i configure internal user to call the ccd pilot number without go thru the ISDN trunk.
problem
1) when the user dials the pilot number directly. the digital phone shows authorised. But if the user dials a trunk seizure follow by the pilot number, it would work.
can someone help to advise how to let the internal user dials the pilot number without going thru the trunk.
thanks
problem
thanks
iourid
You need to create local hybrid loop.
1st. Create a logical link
Inter-Nodes Links / Logical Links (ABC-F)
Link Name : Loop
Link Type + Hybrid
Adjacent Node : 1 /*same node number as your PCX*/
Adjacent Network : 10 /*any network number you don't use except #15*/
Multi access hybrid link + YES
2nd. Create 2 accesses in this logical link
Inter-Nodes Links / Logical Links (ABC-F) / Hybrid Link Access
Link Name : Loop
Access number : 1
Signaling type + B Channel
Link Name : Loop
Access number : 2
3d. To bring hybrid loop up you can try and reset it (rsthyb –f all ) or reboot the system.
Check if link is up with "hybvisu -f all"
Hope it helps,
Iouri
Link Name : Loop
Link Type + Hybrid
Link Name : Loop
Access number : 1
Link Name : Loop
Access number : 2
Hope it helps,
Iouri
nyt88888
nyt88888
when trying to create the second access. i got this error. no error when i create the first access
??Create: Hybrid Link Access????????????????????????????????????
? Node Number (reserved) : 1 ?
? Instance (reserved) : 1 ?
? Link Name : Loop ?
? Access number : 2 ?
? Signaling type + B Channel ?
? Main established tempo : 30 ?
? Has StandBy Signaling + False ?
? StandBy Signaling Type + Unused ?
? Network Date Time Update + NO ?
??Error:????????????????????????????????????????????
? CANCEL to close this window ?
? Processing Failure ?
? OBJECT -1: Access number: No fict. trunk ID free ?
rdclan
wizzy
stefanc_DUP
Re: ccd pilot number cannot be called by internal user.
Thanks Louri, that was the solution.
You rocks ...
/S
You rocks ...
/S
alliance
I'm trying to create a logical hybride loop but the its giving an error (access denied)
Can someone help me on that?
Thks!!
Thks!!
