Hello
I have a strange issue with reports i generate, it is always shows a duration = 224 , therefore the cost would be weird number ,
The pabx is OXO R8
What is the wrong with it and how can i solve it ??
Thanks ..
Please see the attached shot
report with strange duration
Re: report with strange duration
It'a a bug in OXO software. ALE released new version to fix this bug.
Download from Businessportal or ask businesspartner to fix it if you are customer.
Regards LT
Regards LT
New version of what ???
New version of OXO software.
Are sure it is a bug ??
I don't want to go by this long story if there is any other solution .
- cavagnaro
Search the forum and read ALE notes also posted in the forum. If you doubt answers provided then please share your knowledge and show solution
