Questions about SIP phones and IPtouch
jhonku
Post by jhonku »
HI;
I have some questions above SIP and OXE :
1)From wich OXE release can I configure IPTouchEE phones as SIP standalone? Wich models? (Documentation talk only about 4008 and 4018)
2)Can SIP 4038EE to be congured as standalone SIP user? from wich release?
3)We can configure some IPtouch as NOE and others IPtouch as SIP on same OXE, or OXE work only in one mode (NOE or SIP)?
4)Anybody has expirience conguring generic SIP phones on OXE? Wich models?On wich OXE release?
Thanks in advance,
J
swinstation
Re: Questions about SIP phones and IPtouch
Post by swinstation »
I do not have experience , but you can find the structure on the attachment,so please if you find the solution please learn me.
jhonku
Post by jhonku »
Yes, I already have this documentation,the TC1255 and several more, and still is no clear for me and remains this questions.
Thanks for your help.
jhonku
Post by jhonku »
Please, can any Administrator move this post to "SIP Extension" forum ?
Thanks in advance.
MrAnMo
Post by MrAnMo »
Yes 4028, 4038 and 4068 EE can also work as a standalone SIP phone. (From R9.1 binaries)
Unfortunately it is not that easy to get them working. I agree that the documentation is not clear.
What I´ve done.
downloaded a tftpserver like http://tftpd32.jounin.net/tftpd32_download.html and run it on my labtop.
Create a directory on my labtop and pointed the tftp to that directory.
In this directory I made 2 files. 1 file sipconfig.txt and the other sipconfig-macaddresofphone.txt
Both file´s contain the same information only in the sipconfig-macaddresofphone.txt the phonenr and name for the sip phone are stored.
I´ve attached the file´s to this post so you can see them for your self.
Step 2. Start the iptouch phone. When 2/5 is shown pres i and #.
First in ip parameter fill in config. Importent by tftp address fill in your ip address of your laptop. Save values and go back to main menu.
Then selcet Soft Infos and then Run Mode. change run mode from NOE to SIP. Save and the phone will reboot.
Now the phone boot. after 3/5 it connects to your tftp server and download the 2 files. If you have specify the correct information in the files then the sipphone will register on the sip proxy.
Good luck
Yes of course it can also be managed with the 4760 SIP server plug in.
luis.molinas
Post by luis.molinas »
Hi MrAnMo, why generates me the error lanpbx.cfg in the TFTP server? I need create this file??
Best Regards,
reju
Post by reju »
Hi Luis.molinas,
I think your phone is running in NOE mode. please change mode to sip as mentioned by Mr.Anmo
luis.molinas
Hi Reju,
Thks for your answer. I changed the mode and the issue is solved.
Best Regards.
OXE_4400
Post by OXE_4400 »
What experience of using 4038 in SIP standalone mode? I am interested in it since exists plan to migrate CCD agents working on 4038 to Genesys SIP server.
Syed
Post by Syed »
Hi ,
does any one have sipconfig.txt and labpbx.cfg.
actually i am trying to configuring alcatel 4018 EE phones with 3CX but i am getting an error " no tftp respose" on TFTP server i recv an error that labpbx.cfg is missing.
Thanks in advance
Syed
Return to “SIP”
