Accepting REFER command from an Asterix IPBX
Joris06
Post by Joris06 »
I try to establish communication between an Asterisk IPBX and an OXE, and I have a problem :
I have 3 users :
A and B are OXE users, and C is an Asterisk user.
If A call C, then C want to transfer the call to B, my Asterisk send a REFER command to the OXE, but, the OXE refuse this command, so the transfer fail.
Is there a way to force my OXE to accept the REFER command ?
Both of my IPBX are directly interconnected, on the same LAN, with no nat between.
Joris
PS : excuse my poor english, I'm french, and I'm not good with foreign languages :/
Re: Accepting REFER command from an Asterix IPBX
OXE rejects? Why?
Can you post some logs?
Also, can't Asterisk maybe configure their OXE trunk to not to use REFER and test?
Joris06
Post by Joris06 »
Here are the logs of my Asterisk server, the last line "503 Service Unavailable" seem to indicate that the OXE reject the command.
I don't know how to log SIP errors on the OXE.
set_destination: Parsing <sip:6041@10.10.11.30;transport=UDP> for address/port to send to
set_destination: set destination to 10.10.11.30:5060
Reliably Transmitting (no NAT) to 10.10.11.30:5060:
REFER sip:6041@10.10.11.30;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 10.10.11.81:5060;branch=z9hG4bK2b74a42d
Max-Forwards: 70
From: <sip:6199@10.10.11.81;user=phone>;tag=as5546fe5d
To: <sip:6041@10.10.11.30;user=phone>;tag=9da5aa2f809d80b0ef3870f033d27d93
Contact: <sip:6199@10.10.11.81:5060>
Call-ID: ff8706c24b59bcc1d3784d17a17e8587@10.10.11.30
CSeq: 102 REFER
User-Agent: Asterisk PBX 1.8.13.1~dfsg1-3+deb7u3
Refer-To: <sip:6042@oxe>
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Referred-By: <sip:6199@10.10.11.81:5060>
Content-Length: 0
<--- SIP read from UDP:10.10.11.30:5060 --->
SIP/2.0 202 Accepted
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
Contact: <sip:6041@10.10.11.30;transport=UDP>
Supported: replaces,timer,path,100rel
User-Agent: OmniPCX Enterprise R11.0.1 k1.520.22.b
CSeq: 102 REFER
Content-Length: 0
--- (11 headers 0 lines) ---
NOTIFY sip:6199@10.10.11.81:5060 SIP/2.0
Content-Type: message/sipfrag
Event: refer
Subscription-State: terminated;reason=noresource
To: <sip:6199@10.10.11.81;user=phone>;tag=as5546fe5d
From: <sip:6041@10.10.11.30;user=phone>;tag=9da5aa2f809d80b0ef3870f033d27d93
CSeq: 672202134 NOTIFY
Via: SIP/2.0/UDP 10.10.11.30;branch=z9hG4bK6f3776962e2a15a1bae0cf4de440d132
Content-Length: 33
SIP/2.0 503 Service Unavailable
I could use an INVITE command instead, but if I do, the SIP channels aren't released, and 2 channels are used until the call is finished.
Joris
Joris06
Post by Joris06 »
I found what was wrong in my configuration :)
It was a newbie mistake : in my Asterisk configuration, I had named my peer "oxe", so in the field "Refer-To" of the "REFER" command, there was "SIP/6042@oxe".
But my OXE was not named "oxe", so the command was rejected because "SIP/6042@oxe" was unknown.
Now it works just fine :)
Joris
Nice. Other option is you to use ip address.
Return to “SIP”
