Incoming Calls aftter 5 rings should rout to attendante
mejust
Post by mejust » 09 Dec 2011 05:55
Hello Guys
I have incoming calls going directly to various extensions , what I want to do is when a direct call isn't answered after 5 rings it should jump to the attendant.
How do I this ?
I read that this is done through Entity but I can´t see where .
Can you help me?
Thks in advanced
mustafa.ahmad
Re: Incoming Calls aftter 5 rings should rout to attendante
Post by mustafa.ahmad » 10 Dec 2011 01:15
modify the timer numbr 4, make it's value to 60.
mejust
Post by mejust » 10 Dec 2011 12:18
mustafa.ahmad wrote:modify the timer numbr 4, make it's value to 60.
Thanks but before changing the timer I need the call to rout to the attendant .
How do I do that ?
mustafa.ahmad
Post by mustafa.ahmad » 11 Dec 2011 01:03
in the entities, whichever one u are using, put the attendant group in the day / night routing.
mejust
Post by mejust » 13 Dec 2011 11:17
mustafa.ahmad wrote:in the entities, whichever one u are using, put the attendant group in the day / night routing.
Thanks I found the solution
Fisrt you go to categories , access categories and validate "DDI Overflow On Total Busy"
Second you must go to "external services " -> Trunk Category and depending on what trunk category your lines are using you must regulate "Overflow Timer on No Reply : 210"
Third like you said put the attendant group in the day / night routing.
IT works fine , after 5 rings it jumps to my attendant .
Thanks mustafa.ahmad for the Hint
jay_210569
Post by jay_210569 » 22 May 2012 05:22
In my case, I need not to forward the DID call to the attendant.
I'm having 5 entities with 3 operators on each entities, but on one of my entity if they call a DID user and the call was not answered it always transfer to the attendant.
All subscribers are using same Public Network COS = 2, on this thread, to be able to make an overflow to the attendant from a DID call, the management on PNCOS & external services, what possible parameter could disable this overflow feature. I have identical configuration on all of my entities in the network, only this entity has a different behavior than the others.
Thank you for your help.
Return to “Entities”
