voicemail supervision key on 4059
beirut
Post by beirut » 27 Nov 2017 13:42
I am looking to create a voicemail supervision key on the attendant 4059 console.
Not available in the list of programmed keys.
Any workaround?
doublezero
Re: voicemail supervision key on 4059
Post by doublezero » 27 Nov 2017 14:10
Which type of voicemail do you use? Maybe Email notification is an option?
Gesendet von meinem A0001 mit Tapatalk
ACFE OXE R11.1 | ACSE OpenTouch R2.0 | ACSE 8770 R2.5
beirut
Post by beirut » 27 Nov 2017 14:59
we are using 4645 local on CS2.
tgn
Post by tgn » 27 Nov 2017 17:50
so buy mymessaging licenses and you can consult your voicemail with any imap email client.
regards...
beirut
Post by beirut » 27 Nov 2017 18:09
I am trying to find to find a solution without buying new licenses.
mgoegel
Post by mgoegel » 28 Nov 2017 00:57
On newer license keys, the IMAP license is included without any additional costs.
Talk to your distributor. This depends maybe on your OXE release.
Regards Mario
Gesendet von iPad mit Tapatalk
beirut
Post by beirut » 28 Nov 2017 08:38
You are right, IMAP was included on R12.0
Thanks!
Return to “Attendant”
