dialing UK local numbers from UK with ISD format does not work
seerawray
Post by seerawray »
Hello Team,
Could some one confirm if there is any restriction calling UK local number with ISD format.
User dials 0 00 44 1706 xxx xxx, where 0 is external trunk access prefix. The call fails.
If he dial 0 01706 xxx xxxx, it works.
On the Active directory the numbers are declared as +44 1706 xxx xxxx, when a user phone number is searched from LDAP and try calling the call fails due to above issue.
Seerawray
tgn
Re: dialing UK local numbers from UK with ISD format does not work
Post by tgn »
alcatel oxe system can be configured to convert the number in the right way (so if a user dials the international format only the national number will be sent trough the external line).
regards...
--- back to basics... focus your eyes on the essential things... ---
seerawray
Post by seerawray »
Thank you TGN!
Return to “Translator”
