When will OXE R9 simulation come out ?
@Patty@
The client want to use SIP + hotel features + GPON.
I heard that in R9, SIP can work with full hotel features.
My office have R8.0 ,so SIP + hotel features is not working well.
Re: When will OXE R9 simulation come out ?
It should be this year, Q3...however....a stable version however...a little longer
Eliott_DUP
or much longercavagnaro wrote:...a little longer
@Patty@
Thank you.
I am waiting for OXE R9 on VMware.
eieieiei
Yes, I hope so.cavagnaro wrote:haha give her some hope!
eieieiei
well procedure should be the same...will let u know
@Patty@
This picture is the solution that the client want to do.
I am not sure that analog set can work with full hotel feature.
- frank
What's GPON ?
We are currently testing R9 as a beta test.
Will be out around the end of the year
krzysioD
Gigabit Passive Optical Network
A technology implemented nowadays by some ISP companies, the idea is this, so if we have some building (500+ appartments) why to go with 500 copper pairs and then use xDSL? or why to go with coaxial and do a 500 CATV modems...
ISP go with fibre, and from fibre they split services. Maybe term Tripleplay is a good word here.
Gpon endpoint are expensive at present, so i've seen many solutions like that: a few endpoint for 1 building and in that building good L3+ switch and 2 pairs of ethernet copper to every apartment.
Very good solution for fast internet (limit is a 10/100 full duplex Ethernet) and IPTV. To have a voice you (the 1st poster or ISP company) go for SIP user + ATA gateway like linksys papt-2.
Maybe putting a GD+SLI16+SLI16... whould be better (modem/fax transparency, clip...., DC -48V or T0 to end-customer etc..) but cost-effective and working scenario is to have many ATAs or channelbank.
End Customer only needs to see a Ethernet connection to internet/iptv and RJ11 connecor (ofter on blue/brown pair from UTP) for phone.
IIRC ALU had some solution for GPON a 3-4 years ago, but price was very, very overwhelming.
