Asterisk and OXE r10.0.49 calling error
xavo95
Re: Asterisk and OXE r10.0.49 calling error
Post by xavo95 »
Cavagnaro:
i never worked with alcatel, i only have worked with asterisk and now i'm starting in alcatel and cisco. i'm a technic, and when two weeks ago i go to client breakdown, i have found a semi burnt OXE, the only thing that we could recover is the hard disk, all are burnt. Then i have talked with the client and he give us the OXE and licences, then i copy OPS from hard disk, install OmniPCX 10.1 in VMware and recover OPS.
Now i'm doing some lab test, and as said before, it's my first time with alcatel, so cavagnaro, sorry for my unknowing
Unfortunately you need real hardware as said before. Without that there is almost nothing you can do with only the OXE VM. No GD, no GPA, no compressor for VOIP... No digital boards...
Only with OMS from R11. Otherwise you need at least one GD with voip compressors.
xavo95
Post by xavo95 »
cavagnaro:
thanks for explanation, and thanks for install video, it's really helpful
tot3nkopf:
OMS? Optical Managment system?
Do you mean OXE r11? If you mean OXE r11, i have access to installer, if it could be virtualized, i can migrate the OPS to R11(if it's compatible)
xavo95 wrote: OMS? Optical Managment system?
OMS - OXE MEDIA SERVICES
It is a GD/GA virtualized with some restrictions. You need also a specific license in order to use it.
License for R11 and license for use those new virtual platforms.
xavo95
Post by xavo95 »
really thanks for the effort trying to resolve my issue. really appreciated
for future plans, i consider to buying r11
Return to “Asterisk”
