Fail Remoto install of patch
Marce11uy
Post by Marce11uy » 15 Apr 2016 12:18
Hi all,
I'm trying for first time to use the swinst "9 Remote download" procedure, the final intention is to do a patch upgrade on several PCS form the main CS.
Before that, I'm testing this procedure on my lab, I'm using two CS-2 servers connected by a switch and on the same net.
I uploaded successfully the static patch release to the "Distributor" CS, but I have one error when i Tried to Install on the "client" CS.
"ERROR: this patch is not compatible with current binaries static patch installation failed THE MODULE linux IS NOT CORRECTLY INSTALLED."
The release of the CS are:
Distibuitor CS R11.1-l1.301-26-a-uy-c82
Client CS R11.1-l1.301-17-f-uy-c82
The patch is l1.301.32
The connectivity between both cs is Ok,also host names are registered on netadmin, i have check with a minor release on en CS distibuitor and is the same result.
I apprecciatte some help for someone have more experience on this procedure.
Thanks in advance,
M
This is the log of patch install procedure:
ALCATEL-LUCENT
FACILITIES Expert menu Installation FACILITIES 2.74.0
1 Packages installation
2 Deliveries installation
3 Cloning & duplicate operations
4 Backup & restore operations
5 OPS configuration
6 System management
7 Database tools
8 Software identity display
9 Remote download
Q Go back to previous menu
Your choice [1..9, Q] ? 9
ALCATEL-LUCENT
Remote Download menu Installation FACILITIES 2.74.0
1 Remote install of a client CPU
2 Retry the last remote install operation (if justified)
3 About last remote install (if trace exists)
4 Remote load a CPU as master or distributor
5 Retry the last remote load operation (if justified)
6 About last remote load operation (if trace exists)
7 Cleaning operation on master/distributor CPU
8 Programmed operations
9 Fast Delta programmed operations
Your choice [1..9, Q] 1
Enter the name or IP address of the MASTER/DISTRIBUTOR CPU
(return for this CPU, q to quit) ->
Enter the name or IP address of the CLIENT CPU
(return for this CPU, q to quit) -> 192.168.0.221
The MASTER/DISTRIBUTOR CPU is : oxelab
The CLIENT CPU is : 192.168.0.221
Please confirm this choice (y/n, default y):
Checking connections
No delta is available on the master/distrib CPU
No version is available on the master/distrib CPU
One patch is available on the master/distrib CPU : l130132
Remote install it (y/n, default y): y
No dynamic patch is available on the master/distrib CPU
No encryption patch is available on the master/distrib CPU
Confirm the remote install of l130132 (y/n, default y): y
Master checking before remote installation
1 for presence of files (default)
2 for checksum of files
q to quit
=> 2
Client checking after remote installation
1 for no check (default)
2 for size of files
3 for size and checksum of files
q to quit
=> 3
Installing client CPU ...
******* REMOTE INSTALL CLIENT v2.47 *******
Master or distrib CPU : oxelab
Client CPU : xa000000
Client country : uy
Retry mode : no
Checking files after installation : all
DATE : 04/15/16 TIME : 12:51:32
Remote install of l130132
Checking Master/Distrib CPU completude ...
The master or distrib CPU checking is correct
BEGIN INSTALLATION OF MODULE linux...
OPERATION ABORTED
DATE : 04/15/16 TIME : 12:51:41
Press return
Re: Fail Remoto install of patch
Post by cavagnaro » 15 Apr 2016 13:21
Is that patch a minor patch or full installation?
Marce11uy
Post by Marce11uy » 15 Apr 2016 14:00
Hi Cavagnaro,
Thanks for your help.
This patch is an static patch, not a full sw installation.
Marce11uy
Post by Marce11uy » 15 Apr 2016 16:42
Problem solved.
I must to be check the inactive partition version, this version doesn't complain con main version of sofware patch.
I cloned both partition then the remote installation work fine.
M
Post by cavagnaro » 15 Apr 2016 17:05
Thanks for sharing solution
Return to “Software Loading”
