PC Installer Running Problem
giovanni.attolini
Post by giovanni.attolini »
Hi friends,
I am doing PCS upgrade of customer's sites and for this I installed PC Installer in a customer server. The OS is Windows 2008 R2, the installation is ok, but when I run PC Installer I get this message on DOS window
enter in
after call
Using a hash as a reference is deprecated at C:/Program Files (x86)/Alcatel-Luce
nt/OmniPCX Enterprise PC Installer/lib/Lang.pm line 144.
Using a hash as a reference is deprecated at bootnet2.pl line 673.
and the PC Installer window doesn't appear. I tried reinstall, execute like admin, disable the second ethernet interface, disable firewall but without success. Seems to be some a Perl problem...
Somebody for help me?
thanks
Giovanni A. Attolini
tgn
Re: PC Installer Running Problem
Post by tgn »
is there another (newer) perl installation on this server?
try to install in another folder (not program files (x86)).
regards...
alex
Post by alex »
Not sure it would ever work in Windows server 2008
giovanni.attolini
tgn wrote:is there another (newer) perl installation on this server?
regards...
No, there isn't another perl installation. I searched for perl in server but I didn't find.
I tried install in another folder but happens the same.
You possibly right, I am trying install in an unsupported OS.
Thanks tgn and alex, I will try some tricks here and if I have success I will inform you.
giovanni.attolini
Late, but here is the solution:
- Activate "Computer Browser Service"
After this activation, PC Installer worked normally.
tgn
Post by tgn »
thx for sharing.
regards...
oh even after two years and you share the solution
many many thanks
Return to “Software Loading”
