Hi there
I am having some problems with PC Installer. When I run it I receive the follow error:
FTPD: this service is already running on your computer...
I read some posts here where Frank said to delete VPN, disable firewall, etc.
Well, I was using my PC where I had openVPN, VPN clients. I deleted every them but the problem remained.
So, I got a new PC and installed Windows XP with SP3, disabled the firewall, It doesn't anti virus and I installed PC Installer. When I run the same error happens.
I attached two pictures, the error and the folder structure of dhs3mgr.
Any help is welcome.
But really, I can't understand how AL prodeces a simple software a lot of problems.
Error on PC Installer
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
