GD ip address
alex.marete
GD ip address
Post by alex.marete » 02 Apr 2010 05:53
Dear all,
I have an OXE R9.0. once i progran a static IP address in the GD, it doesnt connect to the CS. If i choose dynamic mode, its allocatd an address and system works correctly. Any idea why i cant use static ip.
AM
komar_666
Post by komar_666 » 06 Apr 2010 10:28
Check your configuration, Ip, netmask, and Mac adress in oxe
sera544
Post by sera544 » 07 Apr 2010 01:30
Hi alex,
Check IP parameters>INTIP>Ethernet address checked by TFTP make it false, make sure u declare the GD mac address in the system, Now u can configure the static IP,
cheers
Post by vad » 07 Apr 2010 01:56
sera544 wrote:Hi alex,
cheers
For security reason IP parameters>INTIP>Ethernet address checked by TFTP = true
Just declare GD MAC address in Shelf/ Board/ Ethernet parameters
swinstation
Post by swinstation » 07 Apr 2010 12:53
IT happened to me today in r9.some of the others I turn the switch off and after turning on it worked but now it doesn't work.any idea?
alex.marete
Post by alex.marete » 08 Apr 2010 04:49
Further checks show that once i enter the IP addresses of both CPU in GD mgconfig, the GD never comes on. If i enter only the CPU address of the master CPU then the static address is recognized.
The system is duplicated.
Post by tot3nkopf » 04 May 2010 05:24
lanpbxbuild configured ok?
Post by vad » 04 May 2010 05:42
If you have two CS in one LAN - manage CS role address in GD parameters.
If you have two CS in different LAN - for both CS you need to manage role addressing. And in mgconfig declare ROLE address for CS1 and CS2.
Return to “MAIN”
