Link Aggregation on 6200
Yanesh
Post by Yanesh » 09 Oct 2008 08:32
Hi guys
Anyone knows how to configure a link aggregation on a 6200 switch. Actually i have 2 link going to an Alcatel 6850 (layer 3). I have already configure the link agg on the 6850 and allow several vlans to pass through but on the 6200 when applying trunk on the link aggregation ports it dont allow me.
any clues
Hope to get a reply ASAP
yanesh
krzysioD
Re: Link Aggregation on 6200
Post by krzysioD » 09 Oct 2008 09:59
any log whats going on? maybe firmware versions of 6200 / 6850?
which ports do you use?
Post by silvio » 09 Oct 2008 12:19
- on a 6200 trunk means 802.1q-Tagging
- port-channel means static LAG
There are 8 predefined port-channels where you have to associate the interfaces:
console(config)# interface port-channel 1
console(config-if)# interface range ethernet g1-2
console(config-if)# description LAG-1
console(config-if)# channel-group 1 mode on
Yanesh
Post by Yanesh » 09 Oct 2008 13:26
Thanks for your reply Sylvio
i have configured same as mentioned
Now i need to pass vlan through this switch. This is where i am stucked. Any clues??
Yanesh
Post by Yanesh » 09 Oct 2008 13:29
"through this switch" i mean through this link agg to the switch 6850.
thanks
Yanesh
Post by silvio » 10 Oct 2008 01:22
for tagging vlan 100 and 101 on the LAG and no tagging of vlan 1 (= default vlan) try this:
console (config) # interface port-channel 1
console (config-if) # switchport mode trunk
console (config-if) # switchport trunk allowed vlan add 100 (or "all" for all vlan)
console (config-if) # switchport trunk allowed vlan add 101
console (config-if) # switchport trunk native vlan 1
Return to “OmniStack LS 6200”
