6248P FATAL ERROR
jovanat
6248P FATAL ERROR
Post by jovanat » 18 Jun 2013 11:15
Hi, we also have a problem with OS6200 FATAL ERROR. After power went down for a short time, when the switch came up, it went into this following loop:
***************** SYSTEM RESET *****************
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.0.13 Built 02-Aug-2009 08:24:59
OS6200 board, based on PPC8247
128 MByte SDRAM. I-Cache 16 KB. D-Cache 16 KB. Cache Enabled.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
Decompressing SW from image-1
100%
OK
Running from RAM...
*** Running SW Ver. 1.7.1.12 Date 29-Mar-2012 Time 17:51:19 ***
HW version is 00.00.01
Base Mac address is: 00:12:cf:9a:88:40
Dram size is : 128M bytes
Dram first block size is : 98304K bytes
Dram first PTR is : 0x2000000
Flash size is: 16M
01-Jan-2000 01:01:05 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:05 %CDB-I-LOADCONFIG: Loading startup configuration.
01-Jan-2000 01:01:07 %ERHG-F-SEND: BOXP_perform_smi_scan_of_devices_in_slot: wrong dev. number: actual = 6, program = 7
***** FATAL ERROR *****
Reporting Task: ROOT.
Software Version: 1.7.1.12 (date 29-Mar-2012 time 17:51:19)
0xa7e60
0x44ad80
0x2b5c54
0x2b6110
0x2ba190
0x2d97f8
0x2d9ac8
0x5f1070
0x5f16e0
0x5f1c90
0x60cd74
0x61c4a0
0x56a9b8
0x570b7c
0x454ffc
0xc850c
0xa05e0
As I saw, some of you have already had this problem, and I was wondering have you managed to solve it and how?
I entered Startup menu, and I downloaded new software version, but I succeeded to download only software.img file (when I tried to download bootrom.bin and software.lsm, it reported "error"). After I downloaded software.img, it went in "WARM BOOT", but nothing changes...
And unfortunately, in Startup menu, there is no option "Erase Flash sector", only "Erase flash file", and therefore I don't have possibility to erase entire flash memory and go from scratch.
Anybody can help?
Thanks in advance.
Jovana
fagnerock
Re: 6248P FATAL ERROR
Post by fagnerock » 17 Jun 2014 07:50
Good morning,
in Startup menu has a hidden Advanced menu pressing Ctrl+Shift+6 and there exists a Erase Flash Sectors option.
mirceahuh
Post by mirceahuh » 19 Nov 2014 14:11
Did you managed the make it work?
Can you please share the info, because I have the same problem.
Thank you.
Return to “OmniStack LS 6200”
