cs_ccm_mip_Skel.c alert file
hombrezuelo
Post by hombrezuelo » 28 Nov 2016 13:33
Hi every one, I'm getting the following messsages on my Alcatel-Lucent 6400
Application Level Log Message Toggles table sort mode for field selection. Toggles sort direction for the table.
CCM-CHASSIS alert ******* CS Debug: STR NON FATAL ********
CCM-CHASSIS alert Source file name : cs_ccm_mip_Skel.c
CCM-CHASSIS alert Line number in the file: 7797
CCM-CHASSIS alert Error number : 00000000
CCM-CHASSIS alert Comments : No such instance: rcvd nominator 1 invalid
I would like to know about it and what would be the consequences of those alerts, I hope some one can point me in the right address to know about it.
thanks in advance.
devnull
Re: cs_ccm_mip_Skel.c alert file
Post by devnull » 29 Nov 2016 02:05
Easiest way: reboot, software update.
Longer way: Open a Ticket, they will tell you to reboot and do a softwareupgrade
hombrezuelo
Post by hombrezuelo » 29 Nov 2016 14:08
okay devnull, so I wonder if this could cause a reboot of the switch?
Thank you.
devnull
Post by devnull » 29 Nov 2016 14:30
Probably - some kind of software issue, that could cause whatever.
hombrezuelo
Post by hombrezuelo » 02 Dec 2016 12:21
Great, I'll update the software version. Thank you devnull
Return to “OmniSwitch 6400”
