Radius server - authentication admin
daac84
Post by daac84 » 18 Jan 2016 10:51
Hey there
I request your help please.
I manage a OmniSwitch but that authentication is done via radius, apply the appropriate settings on the switch, create a test user on locally freeradius proof shifts doing OK, but when I try to access via ssh or telnet logs error.
! AAA:
aaa-server radius "TEST" key 26f41c7e84acba09 host 172.20.69.31 retransmit timeout 2 March 1812 auth-port acct-port 1813
aaa authentication telnet "TEST" "local"
http authentication aaa "TEST"
aaa authentication ssh "TEST"
in freeradius
user
user1 User-Password == "user1"
error in telnet conection is
"Authentication failure : Server configuration error, contact your administrator "
But freeradius register login Ok
which I should add or change lines, and which file freeradius
daac84
Re: Radius server - authentication admin
Post by daac84 » 18 Jan 2016 22:18
hi
read a documentation of http://wiki.freeradius.org/vendor/alcatel-lucent and add
Xylan-Asa-Access = "all",
Xylan-Acce-Priv-F-W1 = 0xFFFFFFFF,
Xylan-Acce-Priv-F-W2 = 0xFFFFFFFF
and pass Ok
MMm other problem , the authentication primary is radius , secondary is local , with user local no pass to secundary , not authenticate
What could it be
Post by silvio » 19 Jan 2016 14:50
What could it be
there is no fallback if the first server is answering in any way. But if the server isn't reachable or the service is down there than the switch will ask local usertable.
daac84
Post by daac84 » 19 Jan 2016 22:27
ok actually, I experimented down service and local user pass Ok
Thank you very much for the help.
Return to “OmniSwitch 6400”
