AOS 6.4.3 Problem with DHCP Server
ert_manz
Post by ert_manz »
hi everyone,
after upgrading to version 6.4.3
in /flash/switch/...
cannot find dhcpd.conf.template
any advice plz ?
thanks in advance
ert_manz
Post by ert_manz »
after install Vr 6.4.3
this statement shown up
TUE SEP 21 05:30:16 : REMOTE_CONFIG (142) error message:
+++ DHCP Response not received in 30s. Failed!
TUE SEP 21 05:30:16 : REMOTE_CONFIG (142) info message:
+++ Remote Configuration Download cannot proceed.
im already make sure my image not corrupted..
maybe there's some procedure to upgrade this OS ?
any advice ?
thx
as attachment the file from Alcatel-BPW.
regards Silvio
ert_manz
Post by ert_manz »
ok thx silvio,
my grade still moderate, i will wait until turn to registered then i can download the document :D
ert_manz
Post by ert_manz »
hi silvio, i cannot download attached files ...
hi,
I can use my download. But you can with BPW-Account download it by yourself.....try this link:
https://service.esd.alcatel-lucent.com/ ... c6ToRdx5gi
regards Silvio
ert_manz
Post by ert_manz »
ok thx silvio.
by the way.. it means by default package for AOS 6.4.3 by default doesn't have any template for DHCP server.
and we must add template first and DHCP server can be use ?
after im add two file you give me, sudenly my switch in state low memory ..
any advice ?
b' regards
herman
in the attached techtip is written about the error in docu.
Do you mean with low memory flash-memory or working memory (show health)?
In flash you should check with for any unnecessary files (like dumpfiles - pmd...).
> ls -r
regards Silvio
ert_manz
Post by ert_manz »
Ok , thanks for your support Silvio
Best Regards
ert_manz
strelok
Re:
Post by strelok »
silvio wrote:
21 Sep 2010 14:38
regards Silvio
Hello, silvio !
Unfortunately, link above doesn't work already.
Does this file (dhcp_6.4.3_GA.zip) still exists ? Could you re-download it ?
