Getting problem will upgrading the firmware of 6850
slixxboy
Post by slixxboy » 31 May 2010 05:49
Hello sir, after when we upgrade the firmware of 6850 from 6.3.1.1085.R01 to 6.4.2.933.R01 we encountered some error like this :
FRI APR 23 19:07:01 : CSM-CHASSIS (103) info message:
+++ WARNING 13: Synchronization commands will not be accepted due to low flash
+++ space systemwide. Remove unwanted files from Primary before contining
ERROR : Commands will not be accepted due to low flash . Remove unwanted files
FRI APR 23 19:07:04 : CSM-CHASSIS (103) info message:
FRI APR 23 19:07:11 : CSM-CHASSIS (103) info message:
What is that mean?
And after they upgrade the switch no problems encountered at all. Question is this normal when upgrade this switch?
Victor
benny
Post by benny » 31 May 2010 10:12
Please post the output of the command "ls -r".
-benny
Benny
Please note that at no time I will provide you with AOS releases. Kindly contact your Business Partner or Alcatel-Lucent for that.
Official Alcatel-Lucent OmniSwitch documentation available at:
Alcatel-Lucent Resource Library
DokuWiki
slixxboy
Post by slixxboy » 31 May 2010 21:54
Hi benny,
This is all I got when I command the ls -r before I upgrade the firmware of 6850
OS6850_Alabang_Admin > ls -r
Listing Directory /flash:
drw 1024 Apr 7 14:21 certified/
-rw 338 Apr 7 17:25 boot.params
-rw 64000 Apr 7 17:25 swlog1.log
-rw 64000 Apr 7 17:26 swlog2.log
drw 1024 Apr 7 16:49 switch/
-rw 11 Nov 26 2008 boot.slot.cfg
-rw 1406672 Mar 31 07:13 Crash.pmd
drw 1024 Nov 26 2008 network/
-rw 20 Aug 27 2008 installed
-rw 19488 Apr 7 17:28 tech_support.log
-rw 74040 Apr 7 17:28 tech_support_layer2.log
-rw 5983 Apr 7 17:28 tech_support_layer3.log
-rw 2474 Apr 7 17:28 tech_support_ospf.log
drw 1024 Apr 7 14:21 working/
Listing Directory /flash/certified:
drw 1024 Apr 7 14:21 ./
drw 1024 Apr 7 17:28 ../
-rw 1599866 Oct 7 2008 K2diag.img
-rw 477370 Oct 7 2008 Ksecu.img
-rw 1738621 Oct 7 2008 K2os.img
-rw 2688094 Oct 7 2008 Kadvrout.img
-rw 14783814 Oct 7 2008 Kbase.img
-rw 3360 Oct 7 2008 Krelease.img
-rw 4905515 Oct 7 2008 Keni.img
-rw 3792 Apr 7 14:21 boot.cfg
-rw 862 Oct 7 2008 software.lsm
Listing Directory /flash/switch:
drw 1024 Apr 7 16:49 ./
-rw 105613 Jun 19 2007 certs.pem
-rw 20 Apr 7 17:25 snmp.engine
-rw 0 Jun 19 2007 pre_banner.txt
drw 1024 Nov 26 2008 avlan/
-rw 1732 Oct 7 2008 label.txt
-rw 973 Jul 31 2007 wv-cert.pem
-rw 963 Jul 31 2007 wv-key.pem
-rw 1732 Mar 22 2008 label.txt.bk
-rw 0 Apr 7 16:49 dhcpBind.db
Listing Directory /flash/switch/avlan:
drw 1024 Nov 26 2008 ./
drw 1024 Apr 7 16:49 ../
-rw 445 Oct 7 2008 topA.html
-rw 358 Oct 7 2008 topB.html
-rw 388 Oct 7 2008 bottomA.html
-rw 384 Oct 7 2008 bottomB.html
-rw 8698 Oct 7 2008 javlan.cab
-rw 12929 Oct 7 2008 javlan.jar
-rw 1121 Oct 7 2008 avlanMacInstall.html
-rw 51200 Oct 7 2008 avlaninstall.tar
-rw 12090 Oct 7 2008 javlan.jar.sig
-rw 5327 Oct 7 2008 javlaninstall.sit
-rw 11698 Oct 7 2008 javlanmacosx.jar
-rw 1722 Oct 7 2008 reconfigApple.html
-rw 445 Mar 22 2008 topA.html.bk
-rw 358 Mar 22 2008 topB.html.bk
-rw 388 Mar 22 2008 bottomA.html.bk
-rw 384 Mar 22 2008 bottomB.html.bk
-rw 463 Mar 22 2008 myLogo.gif.bk
-rw 8698 Mar 22 2008 javlan.cab.bk
-rw 12038 Mar 22 2008 javlan.jar.bk
-rw 1121 Mar 22 2008 avlanMacInstall.html.bk
-rw 51200 Mar 22 2008 avlaninstall.tar.bk
-rw 12090 Mar 22 2008 javlan.jar.sig.bk
-rw 5327 Mar 22 2008 javlaninstall.sit.bk
-rw 11698 Mar 22 2008 javlanmacosx.jar.bk
-rw 1722 Mar 22 2008 reconfigApple.html.bk
Listing Directory /flash/network:
-rw 23040 Oct 7 2008 userTable4
-rw 33 Oct 7 2008 policy.cfg
-rw 404 Oct 7 2008 ssh_host_dsa_key
-rw 358 Oct 7 2008 ssh_host_dsa_key.pub
-rw 91392 Jan 4 12:33 userTable5
-rw 12 Oct 7 2008 lockoutSetting
Listing Directory /flash/working:
9284608 bytes free
Victor
Post by frank » 31 May 2010 21:59
Victor,
I would suggest to login the system, and delete the Crash.pmd and *.log files from the main folder.
This should clear some space. If you really need those files, simply ftp them to your computer first for later use.
slixxboy
Post by slixxboy » 31 May 2010 22:03
Thanks for the quick respond.
So you mean it doesn't affect the operation of a switch whenever they have a files like *.pmd and *.log?
Post by frank » 31 May 2010 22:16
PMD files are crashlog that you could send to the technical support
LOG files are only logs
benny
Post by benny » 01 Jun 2010 03:00
I would like to clarify on Franks post.
- You may delete any log file except the "swlog1.log" and "swlog2.log"
- Those two files are needed for system logging and will always be re-created (with the size of 64k each)
- You can delete Crash.pmd / Memmon.dmp if you don't want to open a SR with Alcatel-Lucent
Hope that helps.
-b
Benny
DokuWiki
slixxboy
Post by slixxboy » 01 Jun 2010 03:55
Thanks benny & frank, for your brief explanation.
gamermic
Re: Getting problem will upgrading the firmware of 6850
Post by gamermic » 26 Jan 2014 21:48
Any way to extract Crash.pmd in Kernel or Miniboot mode?
Is there a link to the userguide for Kernel Mode or Miniboot mode for the switches?
"if there's a will, there's a way!"
Post by silvio » 02 Feb 2014 09:11
with the correct miniboot (from 6.4.3....) you will be able to mount usb.
[Miniboot]-> sysUsbSetAdminState 1
also you can use common commands:
[Miniboot]-> cd "uflash/"
[Miniboot]->pwd
[Miniboot]-> ls
[Miniboot]-> cp “/flash/*.pmd“,“/uflash/“ (maybe "/flash/uflash/" is the correct path - I'm not sure"
there is no document from Alcatel...
