Does 7000 support vlan mobile tag or Ip Phone
mr05350
Post by mr05350 » 19 Jan 2010 01:45
I am wondering does any released version for omnisiwtch 7000 support vlan mobile tag? because i was told that for purpose of implemation IP phone you need to turn on the vlan mobile tag features on the swich.
Best Regards
benny
Post by benny » 19 Jan 2010 16:12
The OS7000 doesn't support the feature vlan mobile-tag. You don't necessarily need to tag traffic on a port to do voice. In case you are not using dot1x or other authentication methods on the port you can still have a dot1q tag for voice and no tag for data traffic (e.g. for the PC connected behind the phone).
Please elaborate on the scenario and I'll able to help better than that.
-benny
Benny
