TechTips - How to use USB key
cedric1
Post by cedric1 »
Hello
Here some collect of my tests with USB key to :
- make auto copy to upgrade a switch with usb key
- disaster recovery to make a load of new code when you have a failure in certified and/or working.
Hope it will make your job easier
Cedric
Re: TechTips - How to use USB key
Hi cedric,
thanks for this docu. It's great.
cedric1
Post by cedric1 »
I show it for 9000, so for 6850 or 6400, just add the good folder , instead 9000 put your model type.
This feature is very helpful
Rgds
Cedric
benny
Post by benny »
I agree with Silvio. Good document Cedric - thanks for sharing it.
dangkita
Post by dangkita »
Hi Celdric,
I dont have Alcatel USB.
If i use my USB, do i have to make it bootable first?
cedric1
Post by cedric1 »
No just try to insert it and check if switch recognize it.
dangkita
Post by dangkita »
when i use command " usb reset", the switch gives me " (Re)start USB...
USB: scanning bus for devices... 1 USB Devices found"
but when i use " usbboot", it gives me " No boot device", so i think my USB boot is wrong. Do you know how to create an usb boot for 6400 or do u have any documents about it ?
cedric1
Post by cedric1 »
hello
If you have good miniboot for usb driver, i think you have to order a key to alu .
Key must be max 500Mbits.
Try it in another system and check.
Cedric
jimmyping
Post by jimmyping »
Hi Cedric,
could you possibly help?
sysUsbDisasterRecoveryTask: ERROR: /uflash not found
Miniboot is correct for usbboot. My 6850 omniswitch will not boot from USB. any ideas?
usb: 6850/certified/(AOS files)
Formatted FAT32 and 512meg stick
Any suggestions will be greatly recieved...
Kind Regards,
JPing
kiszoli134
Post by kiszoli134 »
great!
