Nat Problem!
brayam
Nat Problem!
Post by brayam » 22 Feb 2010 11:26
Hi, I just wonder if the 9700 switch supports the NAT translation? if so, could you tell me how ?
I need your help :(
Thx
benny
Post by benny » 23 Feb 2010 01:04
Hi brayam,
The OS9700 doesn't support NAT.
-benny
Benny
brayam
Post by brayam » 26 Feb 2010 08:59
Hi benny,
So, to set the nat I must use a cisco router for example!! if so, do I have to configure the 802.1Q on the 9700 port related to cisco router and do the same on the cisco router?
and at the router, do I just need to define the static route to reach the different VLANs, or I am forced to configure nat to ?
Thx for help!
cedric1
Post by cedric1 » 26 Feb 2010 12:46
use an interco vlan between cisco and 9700
use def route on 9700 to go to cisco
and use static route on cisco to get to 9700 subnet
nat on cisco
that's it
cedric
maverick
Post by maverick » 04 May 2010 12:42
Hi.
Omniswitch 9700 don´t suport NAT. Exist another equipment Alcatel-Lucent, router 5510, support NAT and other characteritics of AOS.
