If a PC is connected to an Alcatel IP Touch 4028 and is authenticated with EAP-MD5, a EAP-logoff (see note below ALCATEL) is sent to the switch when the PC is disconnected from the phone, however if MAB authentication is used, the switch does not receive anything for the information when the PC is disconnected from the phone, the session remains open and a PC can connect to the network without being authenticated!
OmniPCX Enterprise R9.0 – Release description : EAP-Logoff: without this enhancement, if a PC behind the IP Touch was authenticated, it was
possible to unplug it and connect another device to the network without re-authenticatione!
If the PC behind the IP Touch is unplugged, the IP Touch sends an EAP-LOGOFF message on
behalf of the PC to the switch. The switch sets the specified MAC address to an unauthenticated
state. When the PC is plugged in again, it will need to be re-authenticated.
ANY IDEAS for a solution when using Mac @ Authentication beetween IPTOUCH 40x8 connected on CISCO Switch with a Microsoft 2003 Radius Server ?
examples of authentication messages :
May 16 09:38:10.914: %AUTHMGR-5-START: Starting 'mab' for client (0022.680d.a095) on Interface Gi1/0/2 AuditSessionID 0A8564BE000000420A9D6128
May 16 09:38:11.045: %MAB-5-SUCCESS: Authentication successful for client (0022.680d.a095) on Interface Gi1/0/2 AuditSessionID 0A8564BE000000420A9D6128
May 16 09:38:11.045: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (0022.680d.a095) on Interface Gi1/0/2 AuditSessionID 0A8564BE000000420A9D6128
May 16 09:38:11.045: %AUTHMGR-5-VLANASSIGN: VLAN 264 assigned to Interface Gi1/0/2 AuditSessionID 0A8564BE000000420A9D6128
May 16 09:38:11.418: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (0022.680d.a095) on Interface Gi1/0/2 AuditSessionID 0A8564BE000000420A9D6128
