outgoing call number identification
kamel
Post by kamel » 21 Aug 2007 06:53
Alcatel 4400
some phonesets have number identicfication active when calling outside and some not - where to set it?
additionaly this works only when going outside with prefix *78, with 0 it does not work - where to configure that?
thanks in advance,
kamel
Re: outgoing call number identification
Post by vad » 21 Aug 2007 07:44
TG NPD selector - you can find used NPD.
Translator/ Ext.numb plan /Numbering plan description - in NPD (used in TG) you can authorize "personal calling number use".
And last - in user parameters "Use personal calling number=true/false" and "Personal calling number" - you can manage personal number if Use personal calling number=true.
kamel
Post by kamel » 21 Aug 2007 09:36
Thank you for respone.
I think I have another version of MGR app,
I can not find NPD in TrunkGroup
There is no Ext.numb plan in Translator category.
Post by cavagnaro » 21 Aug 2007 16:33
ON trunk Group is "Compatible with"
knightr1der
Post by knightr1der » 21 Aug 2007 18:47
Correction for Cavagnaro - "compatible with" is for logical discriminator under entity.
For Trunk Group NPD selector you must keep on descending hierachy under trunk group and you will see "Trunk Group NPD Selector" and within there, you will see which NPD has been assigned to the TG;
TRUNK GROUP NPD SELECTOR
This object allows the TRUNK GROUP to select a NUMBERING PLAN DESCRIPTION (NPD) depending on the type of numbering plan (NPI/TON).
Management Mode
This attribute concerns the mgt mode of the Information Elements of byte 3 NPI and TON:
Automatic: manages automatically according to the trunk group type the corresponding elements between NPI/TON and the public/private NUMBERING PLAN DESCRIPTION:
In this mode therefore, none of the numbering plan description numbers is managed in this object.
Normal: normal mode is used to manage the NPI/TON for an outgoing call (Byte 3 calling and called):
Only the numbers of the public and private numbering plan description (NPD) are managed (see attributes public and private Numbering Plan Description (NPD) Nos. in this object).
The numbering plan description (NPD) numbers are managed automatically according to the NPI/TON received.
Expert: Same as normal mode. In addition, this mode is used to manage manually a specific NUMBERING PLAN DESCRIPTOR (NPD) according to the NPI/TON received:
The numbers of the public and private numbering plan description (NPD) are managed (see attributes public and private Numbering Plan Description (NPD) Nos. in this object).
The numbers of the numbering plan description (NPD) according to the NPI/TON received are managed (See all attributes num. plan. ID.....NPD No. in this object).
History repeats itself - because no one listens the first time!
ACSE List
- Rel 9.x Corp
- IP Advanced
- CCD Expert
- OmniTouch CC Premium R8.x
Post by cavagnaro » 21 Aug 2007 23:25
Hum i'll slap the guy who "teach" me that lol
sorry for the bad info, i better read all the manual and until that stay only with my Genesys and OTUC lol
Post by vad » 22 Aug 2007 01:22
If we say about mgr. "mgr -l GEA"
Go to translator - you will see "external numbering plan".
Go to trunk groups/ go down hierarchy - you will see "trunk group NPD selector".
Or your system release before 3.
kamel
Post by kamel » 22 Aug 2007 03:17
It seem like I have an older release
this is menu under Translator category:
┌─Select an object───────────────┐
│ -> Prefix Plan │
│ Suffix Plan │
│ Numbering Plan │
│ Private Network Translator │
│ Public Network Translator │
│ Ext.Callback Translation │
│ Dialling Command Table │
│ DDI Translation │
│ Authoris.Code Table │
│ ARS Route list │
│ Node Access Prefix │
│ Network Access Prefix │
│ X25 Exc Numbering Plan │
│ Network Routing Table │
│ PIN (Personal Ident.No.) │
│ Private Call Profile │
│ X25 Transcoding │
and this under Trunk Groups -> Go Down Hierarchy:
┌─Trunk Group───────────────────────────┐
│ -> Go down hierarchy │
│ Consult/Modify │
│ Consult/Modify Overview of Object │
│ Modify │
│ Modify Overview of Object │
│ X25 synchronisation │
│ Facilities │
kamel
Post by vad » 22 Aug 2007 04:33
Usually identification will be Installation number (from user Entity) + User number (from DDI translation).
Send or not caller Id - you can manage in user Entity or user can use "secret Id" prefix.
Prefix *78 and 0 - trunk group seizure or ARS? what type of your TG.
If you have ISDN connection - use "t3" command - you will see send or not your PBX calling number and so on.
msanlimit
Post by msanlimit » 28 Apr 2011 04:11
if i turn on "use personal calling number" and try to call somewhere my call always going from my first number in group of numbers 556700 (group 556700-556900).How can i change it to number 556780?
