OmniPCX Enterprise & Exchange 2010
lgarner
Hello All,
I'm still very new to Alcatel PBX's but I'm having a go at setting up EUM 2010 as an external voice mail system for our PCX 4400. We are running R9.1, have SIP & SIP External Voice Mail licenced. We are using a net VX1200 box in between the PBX and Exchange to address TCP/UDP coversion. I have 2 issues.
1. When we call the voice mail system from our desk phones (ip touch 4028's), 'most' of the time there is no audio but sometimes there is. I've compared traces, on the PBX, the VX1200 and Exchange of calls that have audio and those that have no audio and they are same/same apart from the unique identifiers in them. I had thought it was something to do with the compressors (codec's) but I've changed everything to G723 (with compression) and reverted back to G711a (without compression) still with no inprovement. If I call the system from an external number i.e my mobile, it always has audio, the same is the case when I use a SIP Softphone from my desktop using G711a.
2. If I set the voice mail number dir. no. on my user extension to the EUM external voice mail number, exchange never diverts/answers the call. We also have a 4645 voice mail system that works fine when I use it.
Any help would be appreciated, let me know if any particular logs/configs will help.
Cheers
Laurance (From Australia)
Cheers
- tot3nkopf
Re: OmniPCX Enterprise & Exchange 2010
First of all try to detail your config on OXE side (variant of SIP TG -->ISDN or ABCF, etc). Show us 2 traces on sipmotor: one good call and one w/o audio.
1. My best guess is that this is a RTP issue.
2. Forward to external no activated on phone feature cos?
lgarner
So when I got to work today I tested the system straight away.
The first call worked, the next few did not then they started working again, here are the traces
-- Successful call from 6783 (my ip touch phone) to 6690 (Exchange UM) - With Audio
-- Unsuccessful call from 6783 (my ip touch phone) to 6690 (Exchange UM) - No Audio
traced started ...
1301435900 -> EAu: Block Memory Size: 324380
1301435900 -> EAu: Dupli window: 0/1 (max: 1)
1301435902 -> [ipc_thread] IPC Thread : Ipc reception 3349.
1301435902 -> [ipc_thread] IPC Thread : TCL thread signaled.
1301435902 -> [exec_ipc] in 3348.
1301435902 -> [display_ipc_in] ------------ Begin ---------------
1301435902 -> neqt : 1095 Id : -1
1301435902 -> INVITE
1301435902 -> REQUEST URI : <> 6690@10.35.0.175:5060 ; user=phone
1301435902 -> FROM : <GARNER LAURANCE> 6783@10.35.0.75:5060 ; user=phone
1301435902 -> TO : <> 6690@10.35.0.175:5060 ; user=phone
1301435902 -> CAC : 0
1301435902 -> neqt CAC : -1
1301435902 -> CLIR : 0
1301435902 -> SDP :
1301435902 -> ADDRESS : 10.35.1.17 :32514
1301435902 -> ALGOS :
1301435902 -> PCMA
1301435902 -> G723
1301435902 -> 97
1301435902 -> DIRECTION : SEND & RECEIVE
1301435902 -> N_GW_EXT : 1000
1301435902 -> CATEGORY : PRIVATE
1301435902 -> TranferNotAllowed : FALSE
1301435902 -> language : 0
1301435902 -> [display_ipc_in] ------------- End ----------------
1301435902 -> [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 1095--1.
1301435902 -> [CMotorCallManager::onIncomingEvent] New Call created.
1301435902 -> [CMotorCallManager::callFactory].
1301435902 -> [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R9.1 i1.605.21
1301435902 -> [CMotorCallManager::callFactory]=8acab38.
1301435902 -> [CMotorCallManager::onIncomingEvent] eqt=1095 -1.
1301435902 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 1095 inserted.
1301435902 -> [quoteString] => "GARNER LAURANCE"
1301435902 -> 1127[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
1301435902 -> 1127[CMotorCall::setFilterUsedMode] To be traced = 0
1301435902 -> [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
1301435902 -> [onIncomingEvent] INVITE arrived.
1301435902 -> [receiveInviteEvent] Call: eqt: 1095 INITIAL_STATE received an event.
1301435902 -> 1127[CMotorCall::emitInviteMessage] begin.
1301435902 -> 1127[CMotorCall::emitInviteMessage] From: "GARNER LAURANCE" <sip:6783@10.35.0.75;user=phone>
1301435902 -> 1127[CMotorCall::emitInviteMessage] reqUri :sip:6690@10.35.0.175;user=phone
1301435902 -> 1127[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1
1301435902 -> 1127[CMotorCall::emitInviteMessage] Request Uri : sip:6690@10.35.0.175;user=phone
1301435902 -> 1127[CMotorCall::emitInviteMessage] To: <sip:6690@10.35.0.175;user=phone>
1301435902 -> am_I_PCS SCSWorking : NO
1301435902 -> check_PCSstate
1301435902 -> check_PCSstate stat of PCS is : -1
1301435902 -> 1127[CMotorCall::inviteBuildContact] begin. crms00137339
1301435902 -> [137339 - inviteBuildContact] trunk_number=20 extGw =1000.
1301435902 -> [137339-InviteBuildContact] userinfo : 6783
1301435902 -> 1127[CMotorCall::inviteBuildContact] Contact: sip:6783@10.35.0.75
1301435902 -> 1127[CMotorCall::emitInviteMessage] uacGatewayMode=1 uacRefresher=1.
1301435902 -> 1127[CMotorCall::makeRequestSdp] Begin sdp.
1301435902 -> 1127[CMotorCall::makeRequestSdp] Direction: 0.
1301435902 -> 1127[CMotorCall::makeRequestSdp] format 97
1301435902 -> 1127[CMotorCall::makeRequestSdp] Final sdp.
1301435902 -> 1127[CMotorCall::emitInviteMessage] The sdp build.
1301435902 -> 1127[CMotorCall::new_determineTargetsForTheRequest] is not Responsible For This URI.
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] isResolution=0.
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] target is not the local node.
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] nb contacts=1.
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 6690
1301435902 -> [isUserDeclared] 6690@10.35.0.175
1301435902 -> [isUserDeclared] found in the dictionnary.
1301435902 -> [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
1301435902 -> [CGwServAuthenticate::isUserDeclared] external VM.
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest]-->extGw=1000
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] contact : sip:6690@10.35.0.175;user=phone
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] nb available licenses=8 .
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] license OK.
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest]-->pSipAddSpec->getHost()=10.35.0.175
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] user= 6690
1301435902 -> [CGWMngData::isMainServer] CPU is MAIN.
1301435902 -> [CGWMngData::isMainServer] checkwith PCS = 0
1301435902 -> [CMotorCall::makeInitialMotorRequest] count = 3.
1301435902 -> [CMotorCall::makeInitialMotorRequest] service=0 0xbffff0a0.
1301435902 -> [CMotorCall::makeInitialMotorRequest] service=1 0xbfffed40.
1301435902 -> [CMotorCall::makeInitialMotorRequest] service=2 0xbfffe9bc.
1301435902 -> 1127 [CCall::makeGenericRequest] INVITE
1301435902 -> 1127 [CCall::getDialog] Confirmed Dialog is not found (ID = ;)
1301435902 -> 1127 [CCall::getDialog] Initial Dialog Client not found
1301435902 -> 15aa [CDialog::createRequest]
1301435902 -> 15aa [CDialog::buildServicesForAllRequest]
1301435902 -> 15aa [CDialog::createInviteRequest]
1301435902 -> 2138 [CTransaction::changeState] STATE CHANGED TO INITIAL
1301435902 -> 2138 [CTransaction::changeState] notifying the parent dialog
1301435902 -> 15aa [CDialog::onTransactionState(pTrans = 2138, previousState = Terminated, currentState = Initial, reason = None]
1301435902 -> 971 [CRequest::CRequest] Creation of a request
1301435902 -> 971 [CMessage::send] sip_sendMessage (10.35.0.175:5060)
1301435902 -> SEND MESSAGE TO NETWORK (10.35.0.175:5060 [UDP]) (BUFF LEN = 1021)
INVITE sip:6690@10.35.0.175;user=phone SIP/2.0
Accept-Language: en
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFO
Supported: replaces,timer,100rel
User-Agent: OmniPCX Enterprise R9.1 i1.605.21
Session-Expires: 1800;refresher=uac
Min-SE: 900
P-Alcatel-CSBU: categparty=internal;call_condition=localdirect
Content-Type: application/sdp
From: "GARNER LAURANCE" <sip:6783@10.35.0.75;user=phone>;tag=cc3bb637cc1aa21745852bc833858ac0
Contact: <sip:6783@10.35.0.75;transport=UDP>
Call-ID: aef883e7e09650271a76343d8536891e@10.35.0.75
CSeq: 1615119904 INVITE
Via: SIP/2.0/UDP 10.35.0.75;branch=z9hG4bKadef2beb4252a4fc3c43aab735be6e35
Max-Forwards: 70
Content-Length: 261
v=0
o=OXE 1301435902 1301435902 IN IP4 10.35.0.75
s=abs
c=IN IP4 10.35.1.17
t=0 0
m=audio 32514 RTP/AVP 8 4 97
a=sendrecv
a=rtpmap:8 PCMA/8000
a=ptime:30
a=maxptime:30
a=rtpmap:4 G723/8000
a=ptime:30
a=maxptime:30
a=rtpmap:97 telephone-event/8000
1301435902 -> 2138 [CTransInitialState::createRequest] Transaction changes to Calling state
1301435902 -> 2138 [CTransaction::changeState] STATE CHANGED TO CALLING
1301435902 -> 15aa [CDialog::onTransactionState(pTrans = 2138, previousState = Initial, currentState = Calling, reason = Request creation]
1301435902 -> 2138 [CTransaction::startTimer] Timer A is started (delay = 500 ms)
1301435902 -> 2138 [CTransaction::startTimer] Timer B is started (delay = 8000 ms)
1301435902 -> 15aa [CDialog::addTransaction] added transaction 2138 with branch z9hG4bKadef2beb4252a4fc3c43aab735be6e35, with CSeq 1615119904
1301435902 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
1301435902 -> [CSessionTimerContext::updateAfterRefreshCreation] Update CSessionTimerContext (refresh creation)
1301435902 -> [CSessionTimerContext::updateSupported] Request timer supported
1301435902 -> [CSessionTimerContext::updateMinSE] Min-SE updated : 900
1301435902 -> [CSessionTimerContext::updateSessionExpires] header value : 1800
1301435902 -> [CSessionTimerContext::updateSessionExpires] updated
1301435902 -> [CSessionTimerContext::updateSessionExpires] Refresher updated : i
1301435902 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] nb contact=1.
1301435902 -> [CForkedBranch::CForkedBranch] context = 0x8acaf6c.
1301435902 -> 1127[CMotorCall::branchAllocation] built branch number=1.
1301435902 -> 1127[CMotorCall::branchAllocation] pForkedBranch = 0x8ac3fc8.
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] reqUri duplication pForkedBranch = 0x8ac3fc8.
1301435902 -> 1127[CMotorCall::makeInitialMotorRequest] reqUri duplication2.
1301435902 -> 1127[CMotorCall::getOutgoingCall] outgoingCall:1
1301435902 -> 1127 [CCall::getCallDuplicationData]
1301435902 -> [CViaSetSerializer::copy] Added via 7ce9 at index 0
1301435902 -> 1127 [CCall::getCallDuplicationData] : Request URI = sip:6690@10.35.0.175;user=phone, Call ID = aef883e7e09650271a76343d8536891e@10.35.0.75, Local URI = sip:6783@10.35.0.75;user=phone, Local Tag = cc3bb637cc1aa21745852bc833858ac0, Remote URI = sip:6690@10.35.0.175;user=phone, Remote Tag = , Local CSeq = 1615119904, Remote CSeq = 0
1301435902 -> [CViaSetSerializer::serialize] Serialized via set : ViaSerialize=Via: SIP/2.0/UDP 10.35.0.75;branch=z9hG4bKadef2beb4252a4fc3c43aab735be6e35
1301435902 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1301435902 -> [onIncomingEvent] CallID must be inserted.
1301435902 -> [onIncomingEvent] CallID inserted.
1301435902 -> [exec_ipc] in end 3348.
1301435902 -> RECEIVE MESSAGE FROM NETWORK (10.35.0.175:5060 [UDP])
SIP/2.0 100 Trying
Contact: <sip:6690@10.35.0.175;transport=UDP>
Min-SE: 900
Allow: INVITE, ACK, BYE, CANCEL, REGISTER, NOTIFY, OPTIONS, PRACK, REFER, SUBSCRIBE, UPDATE
Server: SHOUT 4.7.2v29
Content-Length: 0
1301435902 -> [CIOCom::receiveResponse] CResponse AB9 ref=1
1301435902 -> [CDispatcher::onIncomingResponse]
1301435902 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1301435902 -> 102 [CCallManager::onIncomingResponse]
1301435902 -> 1127 [CCall::receiveResponse] 100
1301435902 -> 1127 [CCall::receiveResponse]Trying to find the right dialog
1301435902 -> 1127 [CCall::getDialog] Confirmed Dialog is not found (ID = cc3bb637cc1aa21745852bc833858ac0;)
1301435902 -> 1127 [CCall::getDialog] Returning Initial Dialog Client
1301435902 -> 1127 [CCall::receiveResponse]One dialog found
1301435902 -> 15aa [CDialog::receiveResponse]
1301435902 -> 2138 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
1301435902 -> 2138 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1301435902 -> 15aa [CDialog::onTransactionState(pTrans = 2138, previousState = Calling, currentState = Proceeding, reason = 1xx response reception]
1301435902 -> 2138 [CTransaction::freeTimerToken] Timer A is freed
1301435902 -> 2138 [CTransaction::freeTimerToken] Timer B is freed
1301435902 -> [receiveInformationalMessage] Call: aef883e7e09650271a76343d8536891e@10.35.0.75 eqt: 1095 PROCEEDING_STATE received a message.
SIP/2.0 183 Session Progress
To: <sip:6690@10.35.0.175;user=phone>;tag=50410154
Min-SE: 900
Content-Length: 0
1301435902 -> [CIOCom::receiveResponse] CResponse ABA ref=1
1301435902 -> 1127 [CCall::receiveResponse] 183
1301435902 -> 1127 [CCall::getDialog] Confirmed Dialog is not found (ID = cc3bb637cc1aa21745852bc833858ac0;50410154)
1301435902 -> AB9 [~CResponse] resp(100) aef883e7e09650271a76343d8536891e@10.35.0.75 1615119904 INVITE
1301435902 -> 15aa [CDialog::updateRouteSet] there are 0 record-route headers
1301435902 -> [methodAllowedByDistant] UPDATE allowed by distant.
1301435902 -> 1127[emitEventToMonitel] content size (lginfo): 656
1301435902 -> 1127[emitEventToMonitel] CAC = 0 eqtCAC = -1
1301435902 -> [sendLgEvtSip] Event sent on eqt : 1095 Id :-1
1301435902 -> [display_ipc_out] ------------ Begin ---------------
1301435902 -> Id : -1
1301435902 -> INFORMATIONAL
1301435902 -> xx : 83
1301435902 -> RELATIVE REQUEST : INVITE
1301435902 -> Allow Update : 1
1301435902 -> [display_ipc_out] ------------- End ----------------
Min-SE: 900
Content-Length: 0
1301435902 -> [CIOCom::receiveResponse] CResponse ABB ref=1
1301435902 -> ABA [~CResponse] resp(183) aef883e7e09650271a76343d8536891e@10.35.0.75 1615119904 INVITE
SIP/2.0 180 Ringing
Min-SE: 900
Content-Length: 0
1301435902 -> [CIOCom::receiveResponse] CResponse ABC ref=1
1301435902 -> 1127 [CCall::receiveResponse] 180
1301435902 -> ABB [~CResponse] resp(183) aef883e7e09650271a76343d8536891e@10.35.0.75 1615119904 INVITE
1301435902 -> [methodAllowedByDistant] INFO not allowed by distant !!
1301435902 -> xx : 80
SIP/2.0 200 OK
Allow-Events: message-summary, talk, vq-rtcpxr
Supported: 100rel, timer, replaces
P-Asserted-Identity: <sip:6690@10.8.0.24;user=phone>
Content-Length: 212
v=0
o=SHOUT 0 0 IN IP4 10.35.0.175
s=SIP call via SHOUT
c=IN IP4 10.35.0.175
t=0 0
m=audio 16386 RTP/AVP 8 13 97
a=rtpmap:13 CN/8000
a=fmtp:97 0-15
1301435902 -> [CIOCom::receiveResponse] CResponse ABD ref=1
1301435902 -> 1127 [CCall::receiveResponse] 200
1301435902 -> 15aa [CDialog::receiveResponse] create a CONFIRMED dialog
1301435902 -> 15ab [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bKadef2beb4252a4fc3c43aab735be6e35
1301435902 -> 15ab [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bKadef2beb4252a4fc3c43aab735be6e35
1301435902 -> 2139 [CTransaction::CTransaction] Transaction is cloned in 4 state
1301435902 -> 15ab [CDialog::addTransaction] added transaction 2139 with branch z9hG4bKadef2beb4252a4fc3c43aab735be6e35, with CSeq 1615119904
1301435902 -> 15ab [CDialog::startDialogTTL]
1301435902 -> 15ab [CDialog::receiveResponse]
1301435902 -> 2139 [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
1301435902 -> 2139 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1301435902 -> 2139 [CTransaction::changeState] notifying the parent dialog
1301435902 -> 15ab [CDialog::onTransactionState(pTrans = 2139, previousState = Proceeding, currentState = Completed, reason = Final resp reception]
1301435902 -> 2139 [CTransaction::startTimer] Timer D is started (delay = 32202 ms)
1301435902 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Client, UA)
1301435902 -> [CSessionTimerContext::updateAfterResponseRefreshReception] Update CSessionTimerContext (response refresh reception)
1301435902 -> [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
1301435902 -> [CSessionTimerContext::startTimers] Start session timer will expires : 900000
1301435902 -> [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
1301435902 -> 15ab [CDialog::updateRouteSet] there are 0 record-route headers
1301435902 -> 1127 [CCall::insertInDialogMap] added dialog #15ab with the key cc3bb637cc1aa21745852bc833858ac0;50410154
1301435902 -> 15aa [CDialog::getTransactionByCSeq] CSeq = 1615119905
1301435902 -> [CForkedBranch::setFinalResponse] pResponse=0x8acb3e8.
1301435902 -> [CForkedBranch::setFinalResponse] response=200.
1301435902 -> 1127[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
1301435902 -> 1127[CMotorCall::chooseBestResponse] pForkedBranch=0x8ac3fc8 iResponseCode=2000.
1301435902 -> [CForkedBranch::getResponseCode] response=200.
1301435902 -> 1127[CMotorCall::chooseBestResponse] last iResponseCode=200.
1301435902 -> 1127[CMotorCall::chooseBestResponse] next branch.
1301435902 -> 1127[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
1301435902 -> [receiveSuccessfulMessage] Call: aef883e7e09650271a76343d8536891e@10.35.0.75 eqt: 1095 PROCEEDING_STATE received a message.
1301435902 -> 1127[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=1 uacRefresher=1.
1301435902 -> [checkSdpValidity] Sdp contains 1 media description(s).
1301435902 -> [checkSdpValidity] Media 0 type 1 contains 3 formats.
1301435902 -> [checkSdpValidity] Format : 8.
1301435902 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1301435902 -> [convertSdpIntoTsdp] default T38 config.
1301435902 -> [convertSdpIntoTsdp] No Direction in the session part.
1301435902 -> [convertSdpIntoTsdp] Check the direction in Session part - result:0.
1301435902 -> [convertSdpIntoTsdp] The audio media contains 3 format(s).
1301435902 -> [convertSdpIntoTsdp] Format 0 is 8.
1301435902 -> [convertSdpIntoTsdp] Format 1 is 13.
1301435902 -> [convertSdpIntoTsdp] Format 2 is 97.
1301435902 -> [convertSdpIntoTsdp] Get the direction.
1301435902 -> [convertSdpIntoTsdp] No Direction in this media part.
1301435902 -> [convertSdpIntoTsdp] The connection is at session level.
1301435902 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 10.35.0.175.
1301435902 -> [convertIPStrIntoTuipv] 10.35.0.175 => 10.35.0.175
1301435902 -> SUCCESSFUL
1301435902 -> xx : 0
1301435902 -> COLP : 1
1301435902 -> SDP :
1301435902 -> ADDRESS : 10.35.0.175 :16386
1301435902 -> PCMA
1301435902 -> 97
1301435902 -> [receiveSuccessfulMessage] SRV_OK received update FROM TAG on the StandBy.
1301435902 -> 1127 [CCall::getCallDuplicationData] : Request URI = , Call ID = aef883e7e09650271a76343d8536891e@10.35.0.75, Local URI = sip:6783@10.35.0.75;user=phone, Local Tag = cc3bb637cc1aa21745852bc833858ac0, Remote URI = sip:6690@10.35.0.175;user=phone, Remote Tag = 50410154, Local CSeq = 1615119904, Remote CSeq = 0
1301435902 -> [CRouteSet::serialize] Serialized route set : Contact=sip:6690@10.35.0.175;transport=UDP
1301435902 -> 1127[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
1301435902 -> 1127[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
1301435902 -> ACK
1301435902 -> [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 1095--1.
1301435902 -> [CMotorCallManager::onIncomingEvent] state = ACCEPTED_STATE.
1301435902 -> [onIncomingEvent] ACK arrived.
1301435902 -> [receiveAckEvent] Call: aef883e7e09650271a76343d8536891e@10.35.0.75 eqt: 1095 ACCEPTED_STATE received an event.
1301435902 -> 1127[CMotorCall::inviteBuildContact] Contact: sip:10.35.0.75
1301435902 -> 1127[CMotorCall::emitAckMessage] begin.
1301435902 -> 1127[CMotorCall::emitAckMessage] SDP ok.
1301435902 -> 1127 [CCall::makeGenericRequest] ACK
1301435902 -> 1127 [CCall::getDialog] Confirmed Dialog found
1301435902 -> 15ab [CDialog::createRequest]
1301435902 -> 15ab [CDialog::buildServicesForAllRequest]
1301435902 -> 15ab [CDialog::createAckRequest]
1301435902 -> 15ab [CDialog::createAckRequest], previous trans 2139 is found
1301435902 -> 15ab [CDialog::createAckRequest], previous trans 2139 is client
1301435902 -> 972 [CRequest::CRequest] Creation of a request
1301435902 -> 15ab [CDialog::buildServicesForAck]
1301435902 -> 972 [CMessage::send] sip_sendMessage (10.35.0.175:5060)
1301435902 -> SEND MESSAGE TO NETWORK (10.35.0.175:5060 [UDP]) (BUFF LEN = 458)
ACK sip:6690@10.35.0.175;transport=UDP SIP/2.0
CSeq: 1615119904 ACK
Via: SIP/2.0/UDP 10.35.0.75;branch=z9hG4bKe14fb0348a46facd2558ccd60d5861f3
Max-Forwards: 70
Content-Length: 0
1301435902 -> 2139 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1301435902 -> 2139 [CTransaction::freeTimerToken] Timer D is freed
1301435902 -> 2139 [CTransaction::changeState] no transaction state, terminated reason : Request creation
1301435902 -> 15ab [CDialog::createAckRequest] successful INVITE is terminated after the ACK is sent
1301435902 -> [CTransaction::notifyDialog]
1301435902 -> [CTransaction::notifyDialog] notify parent dialog
1301435902 -> 15ab [CDialog::onTransactionState(pTrans = 2139, previousState = null, currentState = Terminated, reason = Request creation]
1301435902 -> 2139 [~CTransaction] transaction 1615119904 INVITE
1301435907 -> [ipc_thread] IPC Thread : Ipc reception 3349.
1301435907 -> [ipc_thread] IPC Thread : TCL thread signaled.
1301435907 -> [exec_ipc] in 3348.
1301435907 -> [display_ipc_in] ------------ Begin ---------------
1301435907 -> neqt : 1095 Id : -1
1301435907 -> BYE
1301435907 -> [display_ipc_in] ------------- End ----------------
1301435907 -> [CMotorCallManager::onIncomingEvent] an event 10755 arrived on the eqt 1095--1.
1301435907 -> [CMotorCallManager::onIncomingEvent] state = COMPLETED_STATE.
1301435907 -> [onIncomingEvent] BYE arrived.
1301435907 -> [receiveByeEvent] Call: aef883e7e09650271a76343d8536891e@10.35.0.75 eqt: 1095 COMPLETED_STATE received an event.
1301435907 -> 1127 [CCall::makeGenericRequest] BYE
1301435907 -> 1127 [CCall::getDialog] Confirmed Dialog found
1301435907 -> 15ab [CDialog::createRequest]
1301435907 -> 15ab [CDialog::buildServicesForAllRequest]
1301435907 -> 15ab [CDialog::createByeRequest]
1301435907 -> 213a [CTransaction::changeState] STATE CHANGED TO INITIAL
1301435907 -> 213a [CTransaction::changeState] notifying the parent dialog
1301435907 -> 15ab [CDialog::onTransactionState(pTrans = 213a, previousState = Terminated, currentState = Initial, reason = None]
1301435907 -> 973 [CRequest::CRequest] Creation of a request
1301435907 -> 973 [CMessage::send] sip_sendMessage (10.35.0.175:5060)
1301435907 -> SEND MESSAGE TO NETWORK (10.35.0.175:5060 [UDP]) (BUFF LEN = 449)
BYE sip:6690@10.35.0.175;transport=UDP SIP/2.0
From: <sip:6783@10.35.0.75;user=phone>;tag=cc3bb637cc1aa21745852bc833858ac0
CSeq: 1615119905 BYE
Via: SIP/2.0/UDP 10.35.0.75;branch=z9hG4bK2a16094ffacfccf136752e9455fafcbc
Max-Forwards: 70
Content-Length: 0
1301435907 -> 213a [CTransInitialState::createRequest] Transaction changes to Trying state
1301435907 -> 213a [CTransaction::changeState] STATE CHANGED TO TRYING
1301435907 -> 15ab [CDialog::onTransactionState(pTrans = 213a, previousState = Initial, currentState = Trying, reason = Request creation]
1301435907 -> 213a [CTransTryingState::enterInState] Init timers E and F
1301435907 -> 213a [CTransaction::startTimer] Timer E is started (delay = 500 ms)
1301435907 -> 213a [CTransaction::startTimer] Timer F is started (delay = 32000 ms)
1301435907 -> 15ab [CDialog::addTransaction] added transaction 213a with branch z9hG4bK2a16094ffacfccf136752e9455fafcbc, with CSeq 1615119905
1301435907 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1301435907 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1301435907 -> [exec_ipc] in end 3348.
1301435907 -> RECEIVE MESSAGE FROM NETWORK (10.35.0.175:5060 [UDP])
SIP/2.0 200 OK
Content-Length: 0
1301435907 -> [CIOCom::receiveResponse] CResponse ABE ref=1
1301435907 -> [CDispatcher::onIncomingResponse]
1301435907 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1301435907 -> 102 [CCallManager::onIncomingResponse]
1301435907 -> 1127 [CCall::receiveResponse] 200
1301435907 -> 1127 [CCall::receiveResponse]Trying to find the right dialog
1301435907 -> 1127 [CCall::receiveResponse]One dialog found
1301435907 -> 15ab [CDialog::receiveResponse]
1301435907 -> 213a [CTransTryingState::receiveResponse] Final : Transaction changes to Completed state
1301435907 -> 213a [CTransaction::changeState] STATE CHANGED TO COMPLETED
1301435907 -> 15ab [CDialog::onTransactionState(pTrans = 213a, previousState = Trying, currentState = Completed, reason = Final resp reception]
1301435907 -> 213a [CTransaction::freeTimerToken] Timer E is freed
1301435907 -> 213a [CTransaction::freeTimerToken] Timer F is freed
1301435907 -> 213a [CTransaction::startTimer] Timer K is started (delay = 5000 ms)
1301435907 -> 1127[CMotorCall::onReceiveResponse] Update2 the Other context.
1301435907 -> [receiveSuccessfulMessage] Call: aef883e7e09650271a76343d8536891e@10.35.0.75 eqt: 1095 TERMINATED_STATE received a message.
1301435907 -> 1127[emitEventToMonitel] content size (lginfo): 656
1301435907 -> 1127[emitEventToMonitel] CAC = 0 eqtCAC = -1
1301435907 -> [sendLgEvtSip] Event sent on eqt : 1095 Id :-1
1301435907 -> [display_ipc_out] ------------ Begin ---------------
1301435907 -> Id : -1
1301435907 -> SUCCESSFUL
1301435907 -> xx : 0
1301435907 -> RELATIVE REQUEST : BYE
1301435907 -> CLIR : 0
1301435907 -> COLP : 0
1301435907 -> [display_ipc_out] ------------- End ----------------
1301435907 -> SIP EQT RELEASED
1301435907 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1095--1.
1301435907 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 1095 has released its equipment.
1301435907 -> 1127[CMotorCall::emitSipEqtReleaseAck] SIP_EQT_RELEASE_ACK
1301435907 -> UNKNOWN MESSAGE
1301435907 -> 1127[CMotorCall::unRegister] Remove eqt : 1095 diag : -1 from the map.
1301435907 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 1095 erased.
1301435907 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1301435907 -> [CMotorCallManager::onIncomingEvent] killSession.
1301435907 -> 1127 [CCall::killSession]
1301435907 -> 2138 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1301435907 -> 2138 [CTransaction::changeState] no transaction state, terminated reason : None
1301435907 -> 213a [CTransaction::changeState] STATE CHANGED TO TERMINATED
1301435907 -> 213a [CTransaction::freeTimerToken] Timer K is freed
1301435907 -> 213a [CTransaction::changeState] no transaction state, terminated reason : None
1301435907 -> 1127 [CCall::onKill Session Call manager close is called]
1301435907 -> 1127 [CCall::killSession] notifying the call manager
1301435907 -> 102 [CCallManager::onCallClosed]
1301435907 -> 102 [CCallManager::onCallClosed()] Call 1127 closed. Removing call 145533752 from the maps
1301435907 -> [CMotorCallManager::onNotifyCallClosed] Call : aef883e7e09650271a76343d8536891e@10.35.0.75 is closed.
1301435907 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1301435907 -> [CCall::onKill] set callmanager to null
1301435907 -> [CTransaction::notifyDialog]
1301435907 -> [CTransaction::notifyDialog] notify parent dialog
1301435907 -> 15aa [CDialog::onTransactionState(pTrans = 2138, previousState = null, currentState = Terminated, reason = None]
1301435907 -> 15aa [CDialog::onTransactionState] dialog is terminated
1301435907 -> 15aa [CDialog::onTransactionState] onDialogClosed
1301435907 -> 1127 [CCall::onDialogClosed]
1301435907 -> 1127 [CCall::onDialogClosed] not only initial *********
1301435907 -> 1127 [CCall::onDialogClosed]: the dialog 15ab is NOT closed
1301435907 -> 2138 [~CTransaction] transaction 1615119904 INVITE
1301435907 -> ABC [~CResponse] resp(180) aef883e7e09650271a76343d8536891e@10.35.0.75 1615119904 INVITE
1301435907 -> 15ab [CDialog::onTransactionState(pTrans = 213a, previousState = null, currentState = Terminated, reason = None]
1301435907 -> 1127 [CCall::onDialogClosed]: the dialog 15ab is closed
1301435907 -> 1127 [CCall::onDialogClosed] All the dialogs in the Call are closed
1301435907 -> 213A [~CTransaction] transaction 1615119905 BYE
1301435907 -> ABE [~CResponse] resp(200) aef883e7e09650271a76343d8536891e@10.35.0.75 1615119905 BYE
1301435908 -> 102 [CCallManager::removeGarbage] at index i = 0
1301435908 -> 1127[CMotorCall::~CMotorCall] Call : aef883e7e09650271a76343d8536891e@10.35.0.75 is being destructed.
1301435908 -> 1127 [CCall::~CCall]
1301435908 -> 1127 [CCall::removeGarbage]
1301435908 -> 15ab [CDialog::~CDialog]
1301435908 -> 15ab [~CDialog] delete ack request # 0
1301435908 -> 972 [~CRequest] req aef883e7e09650271a76343d8536891e@10.35.0.75 1615119904 ACK
1301435908 -> ABD [~CResponse] resp(200) aef883e7e09650271a76343d8536891e@10.35.0.75 1615119904 INVITE
1301435908 -> 15aa [CDialog::~CDialog]
1301435908 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1301435908 -> 971 [~CRequest] req aef883e7e09650271a76343d8536891e@10.35.0.75 1615119904 INVITE
1301435908 -> 973 [~CRequest] req aef883e7e09650271a76343d8536891e@10.35.0.75 1615119905 BYE
traced started ...
1301435465 -> EAu: Block Memory Size: 324380
1301435465 -> EAu: Dupli window: 0/1 (max: 1)
1301435468 -> [ipc_thread] IPC Thread : Ipc reception 3349.
1301435468 -> [ipc_thread] IPC Thread : TCL thread signaled.
1301435468 -> [exec_ipc] in 3348.
1301435468 -> [display_ipc_in] ------------ Begin ---------------
1301435468 -> neqt : 1095 Id : -1
1301435468 -> INVITE
1301435468 -> REQUEST URI : <> 6690@10.35.0.175:5060 ; user=phone
1301435468 -> FROM : <GARNER LAURANCE> 6783@10.35.0.75:5060 ; user=phone
1301435468 -> TO : <> 6690@10.35.0.175:5060 ; user=phone
1301435468 -> CAC : 0
1301435468 -> neqt CAC : -1
1301435468 -> CLIR : 0
1301435468 -> SDP :
1301435468 -> ADDRESS : 10.35.1.17 :32514
1301435468 -> ALGOS :
1301435468 -> PCMA
1301435468 -> G723
1301435468 -> 97
1301435468 -> DIRECTION : SEND & RECEIVE
1301435468 -> N_GW_EXT : 1000
1301435468 -> CATEGORY : PRIVATE
1301435468 -> TranferNotAllowed : FALSE
1301435468 -> language : 0
1301435468 -> [display_ipc_in] ------------- End ----------------
1301435468 -> [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 1095--1.
1301435468 -> [CMotorCallManager::onIncomingEvent] New Call created.
1301435468 -> [CMotorCallManager::callFactory].
1301435468 -> [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R9.1 i1.605.21
1301435468 -> [CMotorCallManager::callFactory]=8ac76f8.
1301435468 -> [CMotorCallManager::onIncomingEvent] eqt=1095 -1.
1301435468 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 1095 inserted.
1301435468 -> [quoteString] => "GARNER LAURANCE"
1301435468 -> 111c[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
1301435468 -> 111c[CMotorCall::setFilterUsedMode] To be traced = 0
1301435468 -> [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
1301435468 -> [onIncomingEvent] INVITE arrived.
1301435468 -> [receiveInviteEvent] Call: eqt: 1095 INITIAL_STATE received an event.
1301435468 -> 111c[CMotorCall::emitInviteMessage] begin.
1301435468 -> 111c[CMotorCall::emitInviteMessage] From: "GARNER LAURANCE" <sip:6783@10.35.0.75;user=phone>
1301435468 -> 111c[CMotorCall::emitInviteMessage] reqUri :sip:6690@10.35.0.175;user=phone
1301435468 -> 111c[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1
1301435468 -> 111c[CMotorCall::emitInviteMessage] Request Uri : sip:6690@10.35.0.175;user=phone
1301435468 -> 111c[CMotorCall::emitInviteMessage] To: <sip:6690@10.35.0.175;user=phone>
1301435468 -> am_I_PCS SCSWorking : NO
1301435468 -> check_PCSstate
1301435468 -> check_PCSstate stat of PCS is : -1
1301435468 -> 111c[CMotorCall::inviteBuildContact] begin. crms00137339
1301435468 -> [137339 - inviteBuildContact] trunk_number=20 extGw =1000.
1301435468 -> [137339-InviteBuildContact] userinfo : 6783
1301435468 -> 111c[CMotorCall::inviteBuildContact] Contact: sip:6783@10.35.0.75
1301435468 -> 111c[CMotorCall::emitInviteMessage] uacGatewayMode=1 uacRefresher=1.
1301435468 -> 111c[CMotorCall::makeRequestSdp] Begin sdp.
1301435468 -> 111c[CMotorCall::makeRequestSdp] Direction: 0.
1301435468 -> 111c[CMotorCall::makeRequestSdp] format 97
1301435468 -> 111c[CMotorCall::makeRequestSdp] Final sdp.
1301435468 -> 111c[CMotorCall::emitInviteMessage] The sdp build.
1301435468 -> 111c[CMotorCall::new_determineTargetsForTheRequest] is not Responsible For This URI.
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] isResolution=0.
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] target is not the local node.
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] nb contacts=1.
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 6690
1301435468 -> [isUserDeclared] 6690@10.35.0.175
1301435468 -> [isUserDeclared] found in the dictionnary.
1301435468 -> [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
1301435468 -> [CGwServAuthenticate::isUserDeclared] external VM.
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest]-->extGw=1000
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] contact : sip:6690@10.35.0.175;user=phone
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] nb available licenses=8 .
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] license OK.
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest]-->pSipAddSpec->getHost()=10.35.0.175
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] user= 6690
1301435468 -> [CGWMngData::isMainServer] CPU is MAIN.
1301435468 -> [CGWMngData::isMainServer] checkwith PCS = 0
1301435468 -> [CMotorCall::makeInitialMotorRequest] count = 3.
1301435468 -> [CMotorCall::makeInitialMotorRequest] service=0 0xbffff0a0.
1301435468 -> [CMotorCall::makeInitialMotorRequest] service=1 0xbfffed40.
1301435468 -> [CMotorCall::makeInitialMotorRequest] service=2 0xbfffe9bc.
1301435468 -> 111c [CCall::makeGenericRequest] INVITE
1301435468 -> 111c [CCall::getDialog] Confirmed Dialog is not found (ID = ;)
1301435468 -> 111c [CCall::getDialog] Initial Dialog Client not found
1301435468 -> 1599 [CDialog::createRequest]
1301435468 -> 1599 [CDialog::buildServicesForAllRequest]
1301435468 -> 1599 [CDialog::createInviteRequest]
1301435468 -> 2120 [CTransaction::changeState] STATE CHANGED TO INITIAL
1301435468 -> 2120 [CTransaction::changeState] notifying the parent dialog
1301435468 -> 1599 [CDialog::onTransactionState(pTrans = 2120, previousState = Terminated, currentState = Initial, reason = None]
1301435468 -> 959 [CRequest::CRequest] Creation of a request
1301435468 -> 959 [CMessage::send] sip_sendMessage (10.35.0.175:5060)
1301435468 -> SEND MESSAGE TO NETWORK (10.35.0.175:5060 [UDP]) (BUFF LEN = 1021)
Accept-Language: en
Min-SE: 900
From: "GARNER LAURANCE" <sip:6783@10.35.0.75;user=phone>;tag=bd859b066bbbabf61b65e489f06687d1
Call-ID: 5770f41875c2c2f75d152c959adc51d7@10.35.0.75
CSeq: 1563408484 INVITE
Via: SIP/2.0/UDP 10.35.0.75;branch=z9hG4bK62ae8974c873dcd1cdccc1d383e6ae5c
Max-Forwards: 70
Content-Length: 261
v=0
o=OXE 1301435468 1301435468 IN IP4 10.35.0.75
s=abs
c=IN IP4 10.35.1.17
t=0 0
a=sendrecv
a=ptime:30
a=maxptime:30
a=ptime:30
a=maxptime:30
1301435468 -> 2120 [CTransInitialState::createRequest] Transaction changes to Calling state
1301435468 -> 2120 [CTransaction::changeState] STATE CHANGED TO CALLING
1301435468 -> 1599 [CDialog::onTransactionState(pTrans = 2120, previousState = Initial, currentState = Calling, reason = Request creation]
1301435468 -> 2120 [CTransaction::startTimer] Timer A is started (delay = 500 ms)
1301435468 -> 2120 [CTransaction::startTimer] Timer B is started (delay = 8000 ms)
1301435468 -> 1599 [CDialog::addTransaction] added transaction 2120 with branch z9hG4bK62ae8974c873dcd1cdccc1d383e6ae5c, with CSeq 1563408484
1301435468 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
1301435468 -> [CSessionTimerContext::updateAfterRefreshCreation] Update CSessionTimerContext (refresh creation)
1301435468 -> [CSessionTimerContext::updateSupported] Request timer supported
1301435468 -> [CSessionTimerContext::updateMinSE] Min-SE updated : 900
1301435468 -> [CSessionTimerContext::updateSessionExpires] header value : 1800
1301435468 -> [CSessionTimerContext::updateSessionExpires] updated
1301435468 -> [CSessionTimerContext::updateSessionExpires] Refresher updated : i
1301435468 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] nb contact=1.
1301435468 -> [CForkedBranch::CForkedBranch] context = 0x8ac7b2c.
1301435468 -> 111c[CMotorCall::branchAllocation] built branch number=1.
1301435468 -> 111c[CMotorCall::branchAllocation] pForkedBranch = 0x8ab6bc8.
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] reqUri duplication pForkedBranch = 0x8ab6bc8.
1301435468 -> 111c[CMotorCall::makeInitialMotorRequest] reqUri duplication2.
1301435468 -> 111c[CMotorCall::getOutgoingCall] outgoingCall:1
1301435468 -> 111c [CCall::getCallDuplicationData]
1301435468 -> [CViaSetSerializer::copy] Added via 7c83 at index 0
1301435468 -> 111c [CCall::getCallDuplicationData] : Request URI = sip:6690@10.35.0.175;user=phone, Call ID = 5770f41875c2c2f75d152c959adc51d7@10.35.0.75, Local URI = sip:6783@10.35.0.75;user=phone, Local Tag = bd859b066bbbabf61b65e489f06687d1, Remote URI = sip:6690@10.35.0.175;user=phone, Remote Tag = , Local CSeq = 1563408484, Remote CSeq = 0
1301435468 -> [CViaSetSerializer::serialize] Serialized via set : ViaSerialize=Via: SIP/2.0/UDP 10.35.0.75;branch=z9hG4bK62ae8974c873dcd1cdccc1d383e6ae5c
1301435468 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1301435468 -> [onIncomingEvent] CallID must be inserted.
1301435468 -> [onIncomingEvent] CallID inserted.
1301435468 -> [exec_ipc] in end 3348.
1301435468 -> RECEIVE MESSAGE FROM NETWORK (10.35.0.175:5060 [UDP])
SIP/2.0 100 Trying
Min-SE: 900
Content-Length: 0
1301435468 -> [CIOCom::receiveResponse] CResponse A8F ref=1
1301435468 -> [CDispatcher::onIncomingResponse]
1301435468 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1301435468 -> 102 [CCallManager::onIncomingResponse]
1301435468 -> 111c [CCall::receiveResponse] 100
1301435468 -> 111c [CCall::receiveResponse]Trying to find the right dialog
1301435468 -> 111c [CCall::getDialog] Confirmed Dialog is not found (ID = bd859b066bbbabf61b65e489f06687d1;)
1301435468 -> 111c [CCall::getDialog] Returning Initial Dialog Client
1301435468 -> 111c [CCall::receiveResponse]One dialog found
1301435468 -> 1599 [CDialog::receiveResponse]
1301435468 -> 2120 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
1301435468 -> 2120 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1301435468 -> 1599 [CDialog::onTransactionState(pTrans = 2120, previousState = Calling, currentState = Proceeding, reason = 1xx response reception]
1301435468 -> 2120 [CTransaction::freeTimerToken] Timer A is freed
1301435468 -> 2120 [CTransaction::freeTimerToken] Timer B is freed
1301435468 -> [receiveInformationalMessage] Call: 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 eqt: 1095 PROCEEDING_STATE received a message.
To: <sip:6690@10.35.0.175;user=phone>;tag=2910014e
Min-SE: 900
Content-Length: 0
1301435468 -> [CIOCom::receiveResponse] CResponse A90 ref=1
1301435468 -> 111c [CCall::receiveResponse] 183
1301435468 -> 111c [CCall::getDialog] Confirmed Dialog is not found (ID = bd859b066bbbabf61b65e489f06687d1;2910014e)
1301435468 -> A8F [~CResponse] resp(100) 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 1563408484 INVITE
1301435468 -> 1599 [CDialog::updateRouteSet] there are 0 record-route headers
1301435468 -> [methodAllowedByDistant] UPDATE allowed by distant.
1301435468 -> 111c[emitEventToMonitel] content size (lginfo): 656
1301435468 -> 111c[emitEventToMonitel] CAC = 0 eqtCAC = -1
1301435468 -> [sendLgEvtSip] Event sent on eqt : 1095 Id :-1
1301435468 -> [display_ipc_out] ------------ Begin ---------------
1301435468 -> Id : -1
1301435468 -> INFORMATIONAL
1301435468 -> xx : 83
1301435468 -> RELATIVE REQUEST : INVITE
1301435468 -> Allow Update : 1
1301435468 -> [display_ipc_out] ------------- End ----------------
Min-SE: 900
Content-Length: 0
1301435468 -> [CIOCom::receiveResponse] CResponse A91 ref=1
1301435468 -> A90 [~CResponse] resp(183) 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 1563408484 INVITE
SIP/2.0 180 Ringing
Min-SE: 900
Content-Length: 0
1301435468 -> [CIOCom::receiveResponse] CResponse A92 ref=1
1301435468 -> 111c [CCall::receiveResponse] 180
1301435468 -> A91 [~CResponse] resp(183) 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 1563408484 INVITE
1301435468 -> [methodAllowedByDistant] INFO not allowed by distant !!
1301435468 -> xx : 80
SIP/2.0 200 OK
Content-Length: 212
v=0
t=0 0
a=rtpmap:13 CN/8000
a=fmtp:97 0-15
1301435468 -> [CIOCom::receiveResponse] CResponse A93 ref=1
1301435468 -> 111c [CCall::receiveResponse] 200
1301435468 -> 1599 [CDialog::receiveResponse] create a CONFIRMED dialog
1301435468 -> 159a [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bK62ae8974c873dcd1cdccc1d383e6ae5c
1301435468 -> 159a [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bK62ae8974c873dcd1cdccc1d383e6ae5c
1301435468 -> 2121 [CTransaction::CTransaction] Transaction is cloned in 4 state
1301435468 -> 159a [CDialog::addTransaction] added transaction 2121 with branch z9hG4bK62ae8974c873dcd1cdccc1d383e6ae5c, with CSeq 1563408484
1301435468 -> 159a [CDialog::startDialogTTL]
1301435468 -> 159a [CDialog::receiveResponse]
1301435468 -> 2121 [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
1301435468 -> 2121 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1301435468 -> 2121 [CTransaction::changeState] notifying the parent dialog
1301435468 -> 159a [CDialog::onTransactionState(pTrans = 2121, previousState = Proceeding, currentState = Completed, reason = Final resp reception]
1301435468 -> 2121 [CTransaction::startTimer] Timer D is started (delay = 32209 ms)
1301435468 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Client, UA)
1301435468 -> [CSessionTimerContext::updateAfterResponseRefreshReception] Update CSessionTimerContext (response refresh reception)
1301435468 -> [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
1301435468 -> [CSessionTimerContext::startTimers] Start session timer will expires : 900000
1301435468 -> [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
1301435468 -> 159a [CDialog::updateRouteSet] there are 0 record-route headers
1301435468 -> 111c [CCall::insertInDialogMap] added dialog #159a with the key bd859b066bbbabf61b65e489f06687d1;2910014e
1301435468 -> 1599 [CDialog::getTransactionByCSeq] CSeq = 1563408485
1301435468 -> [CForkedBranch::setFinalResponse] pResponse=0x8ac7348.
1301435468 -> [CForkedBranch::setFinalResponse] response=200.
1301435468 -> 111c[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
1301435468 -> 111c[CMotorCall::chooseBestResponse] pForkedBranch=0x8ab6bc8 iResponseCode=2000.
1301435468 -> [CForkedBranch::getResponseCode] response=200.
1301435468 -> 111c[CMotorCall::chooseBestResponse] last iResponseCode=200.
1301435468 -> 111c[CMotorCall::chooseBestResponse] next branch.
1301435468 -> 111c[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
1301435468 -> [receiveSuccessfulMessage] Call: 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 eqt: 1095 PROCEEDING_STATE received a message.
1301435468 -> 111c[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=1 uacRefresher=1.
1301435468 -> [checkSdpValidity] Sdp contains 1 media description(s).
1301435468 -> [checkSdpValidity] Media 0 type 1 contains 3 formats.
1301435468 -> [checkSdpValidity] Format : 8.
1301435468 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1301435468 -> [convertSdpIntoTsdp] default T38 config.
1301435468 -> [convertSdpIntoTsdp] No Direction in the session part.
1301435468 -> [convertSdpIntoTsdp] Check the direction in Session part - result:0.
1301435468 -> [convertSdpIntoTsdp] The audio media contains 3 format(s).
1301435468 -> [convertSdpIntoTsdp] Format 0 is 8.
1301435468 -> [convertSdpIntoTsdp] Format 1 is 13.
1301435468 -> [convertSdpIntoTsdp] Format 2 is 97.
1301435468 -> [convertSdpIntoTsdp] Get the direction.
1301435468 -> [convertSdpIntoTsdp] No Direction in this media part.
1301435468 -> [convertSdpIntoTsdp] The connection is at session level.
1301435468 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 10.35.0.175.
1301435468 -> [convertIPStrIntoTuipv] 10.35.0.175 => 10.35.0.175
1301435468 -> SUCCESSFUL
1301435468 -> xx : 0
1301435468 -> COLP : 1
1301435468 -> SDP :
1301435468 -> ADDRESS : 10.35.0.175 :16386
1301435468 -> PCMA
1301435468 -> 97
1301435468 -> [receiveSuccessfulMessage] SRV_OK received update FROM TAG on the StandBy.
1301435468 -> 111c [CCall::getCallDuplicationData] : Request URI = , Call ID = 5770f41875c2c2f75d152c959adc51d7@10.35.0.75, Local URI = sip:6783@10.35.0.75;user=phone, Local Tag = bd859b066bbbabf61b65e489f06687d1, Remote URI = sip:6690@10.35.0.175;user=phone, Remote Tag = 2910014e, Local CSeq = 1563408484, Remote CSeq = 0
1301435468 -> [CRouteSet::serialize] Serialized route set : Contact=sip:6690@10.35.0.175;transport=UDP
1301435468 -> 111c[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
1301435468 -> 111c[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
1301435468 -> ACK
1301435468 -> [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 1095--1.
1301435468 -> [CMotorCallManager::onIncomingEvent] state = ACCEPTED_STATE.
1301435468 -> [onIncomingEvent] ACK arrived.
1301435468 -> [receiveAckEvent] Call: 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 eqt: 1095 ACCEPTED_STATE received an event.
1301435468 -> 111c[CMotorCall::inviteBuildContact] Contact: sip:10.35.0.75
1301435468 -> 111c[CMotorCall::emitAckMessage] begin.
1301435468 -> 111c[CMotorCall::emitAckMessage] SDP ok.
1301435468 -> 111c [CCall::makeGenericRequest] ACK
1301435468 -> 111c [CCall::getDialog] Confirmed Dialog found
1301435468 -> 159a [CDialog::createRequest]
1301435468 -> 159a [CDialog::buildServicesForAllRequest]
1301435468 -> 159a [CDialog::createAckRequest]
1301435468 -> 159a [CDialog::createAckRequest], previous trans 2121 is found
1301435468 -> 159a [CDialog::createAckRequest], previous trans 2121 is client
1301435468 -> 95A [CRequest::CRequest] Creation of a request
1301435468 -> 159a [CDialog::buildServicesForAck]
1301435468 -> 95A [CMessage::send] sip_sendMessage (10.35.0.175:5060)
1301435468 -> SEND MESSAGE TO NETWORK (10.35.0.175:5060 [UDP]) (BUFF LEN = 458)
CSeq: 1563408484 ACK
Via: SIP/2.0/UDP 10.35.0.75;branch=z9hG4bKada4bf240155ace761c360bc7588569a
Max-Forwards: 70
Content-Length: 0
1301435468 -> 2121 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1301435468 -> 2121 [CTransaction::freeTimerToken] Timer D is freed
1301435468 -> 2121 [CTransaction::changeState] no transaction state, terminated reason : Request creation
1301435468 -> 159a [CDialog::createAckRequest] successful INVITE is terminated after the ACK is sent
1301435468 -> [CTransaction::notifyDialog]
1301435468 -> [CTransaction::notifyDialog] notify parent dialog
1301435468 -> 159a [CDialog::onTransactionState(pTrans = 2121, previousState = null, currentState = Terminated, reason = Request creation]
1301435468 -> 2121 [~CTransaction] transaction 1563408484 INVITE
1301435473 -> [ipc_thread] IPC Thread : Ipc reception 3349.
1301435473 -> [ipc_thread] IPC Thread : TCL thread signaled.
1301435473 -> [exec_ipc] in 3348.
1301435473 -> [display_ipc_in] ------------ Begin ---------------
1301435473 -> neqt : 1095 Id : -1
1301435473 -> BYE
1301435473 -> [display_ipc_in] ------------- End ----------------
1301435473 -> [CMotorCallManager::onIncomingEvent] an event 10755 arrived on the eqt 1095--1.
1301435473 -> [CMotorCallManager::onIncomingEvent] state = COMPLETED_STATE.
1301435473 -> [onIncomingEvent] BYE arrived.
1301435473 -> [receiveByeEvent] Call: 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 eqt: 1095 COMPLETED_STATE received an event.
1301435473 -> 111c [CCall::makeGenericRequest] BYE
1301435473 -> 111c [CCall::getDialog] Confirmed Dialog found
1301435473 -> 159a [CDialog::createRequest]
1301435473 -> 159a [CDialog::buildServicesForAllRequest]
1301435473 -> 159a [CDialog::createByeRequest]
1301435473 -> 2122 [CTransaction::changeState] STATE CHANGED TO INITIAL
1301435473 -> 2122 [CTransaction::changeState] notifying the parent dialog
1301435473 -> 159a [CDialog::onTransactionState(pTrans = 2122, previousState = Terminated, currentState = Initial, reason = None]
1301435473 -> 95B [CRequest::CRequest] Creation of a request
1301435473 -> 95B [CMessage::send] sip_sendMessage (10.35.0.175:5060)
1301435473 -> SEND MESSAGE TO NETWORK (10.35.0.175:5060 [UDP]) (BUFF LEN = 449)
From: <sip:6783@10.35.0.75;user=phone>;tag=bd859b066bbbabf61b65e489f06687d1
CSeq: 1563408485 BYE
Via: SIP/2.0/UDP 10.35.0.75;branch=z9hG4bK6a9077522e89566e0eb64b00e4f5867c
Max-Forwards: 70
Content-Length: 0
1301435473 -> 2122 [CTransInitialState::createRequest] Transaction changes to Trying state
1301435473 -> 2122 [CTransaction::changeState] STATE CHANGED TO TRYING
1301435473 -> 159a [CDialog::onTransactionState(pTrans = 2122, previousState = Initial, currentState = Trying, reason = Request creation]
1301435473 -> 2122 [CTransTryingState::enterInState] Init timers E and F
1301435473 -> 2122 [CTransaction::startTimer] Timer E is started (delay = 500 ms)
1301435473 -> 2122 [CTransaction::startTimer] Timer F is started (delay = 32000 ms)
1301435473 -> 159a [CDialog::addTransaction] added transaction 2122 with branch z9hG4bK6a9077522e89566e0eb64b00e4f5867c, with CSeq 1563408485
1301435473 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1301435473 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1301435473 -> [exec_ipc] in end 3348.
1301435473 -> RECEIVE MESSAGE FROM NETWORK (10.35.0.175:5060 [UDP])
SIP/2.0 200 OK
Content-Length: 0
1301435473 -> [CIOCom::receiveResponse] CResponse A94 ref=1
1301435473 -> [CDispatcher::onIncomingResponse]
1301435473 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1301435473 -> 102 [CCallManager::onIncomingResponse]
1301435473 -> 111c [CCall::receiveResponse] 200
1301435473 -> 111c [CCall::receiveResponse]Trying to find the right dialog
1301435473 -> 111c [CCall::receiveResponse]One dialog found
1301435473 -> 159a [CDialog::receiveResponse]
1301435473 -> 2122 [CTransTryingState::receiveResponse] Final : Transaction changes to Completed state
1301435473 -> 2122 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1301435473 -> 159a [CDialog::onTransactionState(pTrans = 2122, previousState = Trying, currentState = Completed, reason = Final resp reception]
1301435473 -> 2122 [CTransaction::freeTimerToken] Timer E is freed
1301435473 -> 2122 [CTransaction::freeTimerToken] Timer F is freed
1301435473 -> 2122 [CTransaction::startTimer] Timer K is started (delay = 5000 ms)
1301435473 -> 111c[CMotorCall::onReceiveResponse] Update2 the Other context.
1301435473 -> [receiveSuccessfulMessage] Call: 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 eqt: 1095 TERMINATED_STATE received a message.
1301435473 -> 111c[emitEventToMonitel] content size (lginfo): 656
1301435473 -> 111c[emitEventToMonitel] CAC = 0 eqtCAC = -1
1301435473 -> [sendLgEvtSip] Event sent on eqt : 1095 Id :-1
1301435473 -> [display_ipc_out] ------------ Begin ---------------
1301435473 -> Id : -1
1301435473 -> SUCCESSFUL
1301435473 -> xx : 0
1301435473 -> RELATIVE REQUEST : BYE
1301435473 -> CLIR : 0
1301435473 -> COLP : 0
1301435473 -> [display_ipc_out] ------------- End ----------------
1301435473 -> SIP EQT RELEASED
1301435473 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1095--1.
1301435473 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 1095 has released its equipment.
1301435473 -> 111c[CMotorCall::emitSipEqtReleaseAck] SIP_EQT_RELEASE_ACK
1301435473 -> UNKNOWN MESSAGE
1301435473 -> 111c[CMotorCall::unRegister] Remove eqt : 1095 diag : -1 from the map.
1301435473 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 1095 erased.
1301435473 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1301435473 -> [CMotorCallManager::onIncomingEvent] killSession.
1301435473 -> 111c [CCall::killSession]
1301435473 -> 2120 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1301435473 -> 2120 [CTransaction::changeState] no transaction state, terminated reason : None
1301435473 -> 2122 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1301435473 -> 2122 [CTransaction::freeTimerToken] Timer K is freed
1301435473 -> 2122 [CTransaction::changeState] no transaction state, terminated reason : None
1301435473 -> 111c [CCall::onKill Session Call manager close is called]
1301435473 -> 111c [CCall::killSession] notifying the call manager
1301435473 -> 102 [CCallManager::onCallClosed]
1301435473 -> 102 [CCallManager::onCallClosed()] Call 111c closed. Removing call 145520376 from the maps
1301435473 -> [CMotorCallManager::onNotifyCallClosed] Call : 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 is closed.
1301435473 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1301435473 -> [CCall::onKill] set callmanager to null
1301435473 -> [CTransaction::notifyDialog]
1301435473 -> [CTransaction::notifyDialog] notify parent dialog
1301435473 -> 1599 [CDialog::onTransactionState(pTrans = 2120, previousState = null, currentState = Terminated, reason = None]
1301435473 -> 1599 [CDialog::onTransactionState] dialog is terminated
1301435473 -> 1599 [CDialog::onTransactionState] onDialogClosed
1301435473 -> 111c [CCall::onDialogClosed]
1301435473 -> 111c [CCall::onDialogClosed] not only initial *********
1301435473 -> 111c [CCall::onDialogClosed]: the dialog 159a is NOT closed
1301435473 -> 2120 [~CTransaction] transaction 1563408484 INVITE
1301435473 -> A92 [~CResponse] resp(180) 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 1563408484 INVITE
1301435473 -> 159a [CDialog::onTransactionState(pTrans = 2122, previousState = null, currentState = Terminated, reason = None]
1301435473 -> 111c [CCall::onDialogClosed]: the dialog 159a is closed
1301435473 -> 111c [CCall::onDialogClosed] All the dialogs in the Call are closed
1301435473 -> 2122 [~CTransaction] transaction 1563408485 BYE
1301435473 -> A94 [~CResponse] resp(200) 5770f41875c2c2f75d152c959adc51d7@10.35.0.75 1563408485 BYE
lgarner
Wed Mar 30 09:35:23 EST 2011
| C O M P V I S U |
| Inter-node protocol H323....... yes |
| RTP Direct..................... yes |
| RTP Direct for H323 terminals.. no |
| Fast Start..................... yes |
| VAD (Voice Activity Detection): |
| - G723/G729...... yes |
| - G711........... yes |
| ECE (Echo Canceller)........... yes |
| - LIO/LIOE........ 16 ms |
| - INTIP/GA/GD..... 128 ms |
| PFE (Post Filter).............. yes |
| Volume ........................ 8 |
| Volume for IP Phone ........... 0dB |
| Volume for other device. ...... 0dB |
| VRE ........................... no |
| Law (Except Media Gateway)..... A law |
| Global compression type ....... G723 |
| Multi-algorithm (for H323) .... no |
| Compression for INTIP/GD ..... without |
| Compression for IPP ........... without |
| Transit on IP Boards ...........yes |
| ticket Stat IP................. no |
| IP version..................... IPv4 |
| Transit compatibility.......... no |
| Voip Framing G711 ............. 30 ms |
| Voip Framing G723 ............. 30 ms |
| Voip Framing G729 ............. 20 ms |
| No RBT For Direct RTP H323..... no |
| T38 FAX........................ yes |
| C O M P V I S U |
lgarner
(1)arc-vs01> trkvisu 20
Wed Mar 30 09:36:47 EST 2011
local TG ;
****************** data in Trunk_Group structure ****************
******** data REMOTE TRUNK
TrunkName = ARC SIP
discrLogId = -1 ton_a_used = 0 em_repfix = 0
privLine = 0 reservop = 0 reserauto = 0
Trunksearchs = 0 ftranscom = 0 frondier = 0
typTrunk : (6) => T2-SIP
Next_Trunk = -1 nbdigitsem = 0 tab_proto = -1
var IPNS = 1
node_number = 1
network_number = 2
trunk_reg_sig = 0
special_it_par_quantum = 1
cat_restrictionService_in = 10, cat_restrictionService_out = 10
Priority ===> Level= 0, Mode= 0, Preemption= 0
mpt1343 = 0, callbackTrunkbusy = 0 rerouting = 0
******** data Link
cat_signa = 31 ch_channelb = 1 overflow_it = 1 access_turn = 1 network_mode = 0
| ocupjonc for SIP TG
| SIP Trunk group information on TX side
| i = 0, min = 0, max = 3
| (num_crist - num_cpl - num_term) = (19-0-3)
| last it used = 0, monlap = 11, network_mode = 0 nbr_trunk_created = 4
| nbr_trunk_busy : start = 0 arrived = 0 mixed = 0
| it_reserved : start = 0 arrived = 0 mixed = 4
| it_max_Q0 : Start = 0 arrived = 0 mixed = 4
| it_max_Q1 : Start = 0 arrived = 0 mixed = 0
| access_level2 = CONNECT2
| outservice | res | Busy | nulog |trans|neqtdyn|E64 RN64 EN64| OVPN | neqph | adr
| FREE | no | free | 160 | 1 | -1 | 0 0 0 | 0 | 1100 |SIP Trunk 1
| FREE | no | free | 161 | 1 | -1 | 0 0 0 | 0 | 1101 |SIP Trunk 2
| FREE | no | free | 162 | 1 | -1 | 0 0 0 | 0 | 1102 |SIP Trunk 3
| FREE | no | free | 163 | 1 | -1 | 0 0 0 | 0 | 1103 |SIP Trunk 4
| SIP Trunk group information on GX side
| (num_crist - num_cpl - num_term) = (19-0-2)
| monlap = 10, mode_reseau = 1 nbr_jonc_cree = 4
| Trunks from nulog 164 (neqph 1095) to nulog 167 (neqph 1098)
index_max = 7 ; nbjonc = 4
cristal = 0 1 2 3 4 5 6 7 8 9 10 11
LastTrunkused = 0 0 0 0 0 0 0 0 0 0 0 0
cristal = 12 13 14 15 16 17 18 19
LastTrunkused = 0 0 0 0 0 0 0 3
LastTrunkUsed common = 3 idx_rfo = 0 channel_reserv = 0
dert0_used = 0 dert0mixt_used = 0 dert0wo_used = 0
******** data TRUNK_LOCAL
a_paying = 0 Trunkdisa = 0 itpermnt = 1 trans_num = 0
tr_q23 = 0 reach_boss = 0 secretcode = 0 ach_film = 1
accesscode = 0 gp_d_Hold = 0 categ_ptt = 31 blf etat = 1
entity_nr = 10 nb_digit_used = 0 Trunkdissu = 0 dto_about = 0
reused_channelb = 0 number_to_be_added : .
mode_ddi = 0 refptt = / / nbchminp = 0
x25used = 0
vpnRate = 50 vpnCostLimit = 0 immTrkForVpn = 1
businessPercent = 0 nbACDCall = 0 tax_nds = 1
send_prog = 1 ip_qual_prof = Profile #1
t2spec = S_SIP compression_type = 1 (0: Default [ie : G723], 1 : G711)
d_channel_hyb = 0
local TG ;
TrunkName = ARC SIP
var IPNS = 1
node_number = 1
network_number = 2
trunk_reg_sig = 0
******** data Link
| ocupjonc for SIP TG
x25used = 0
d_channel_hyb = 0
lgarner
Export from OnmiVista for Trunkgroup
Trunk Groups
Node arc-vs01
Trunk Group ID 20
Trunk Group Type T2
Trunk Group Name ARC SIP
UTF-8 Trunk Group Name
Node number 1
Transcom Trunk Group No
Auto.reserv.by Attendant No
Overflow trunk group No. -1
Tone on seizure No
Private Trunk Group No
Paging Trunk Group
Paging Table ID
Paging Signalization
Security Patrol
Q931 Signal variant ABC-F
Carrier Protocol Type
SS7 Signal variant No variant
Number Compatible With -1
Send Prefix
Number Of Digits To Send 0
Channel selection type Quantified
Remote Network 2
Shared Trunk Group No
T.line Calling last dig.length
Auto.DTMF dialing on outgoing call NO
T2 Specification MINI SIP
Homogenous network for direct RTP NO
Public Network COS 31
DID transcoding No
Special Services Nothing
Can support UUS in SETUP Yes
Register Signaling
Implicit Priority\Activation mode 0
Implicit Priority\Priority Level 0
Preempter NO
Incoming calls Restriction COS 10
Outgoing calls Restriction COS 10
Callee number mpt1343 NO
Overlap dialing NO
Call diversion in ISDN NO
CUG List Number
Preferential CUG
CUG Outgoing Access
CUG Incoming Access
Trunk Group
Node arc-vs01
Trunk Groups 20
Instance (reserved) 1
Trunk Group Type T2
Public Network Ref.
End-to-end dialing NO
DTMF end-to-end signal. NO
Paying Incoming Calls
TS Permanently assigned
Min. No. of digits on seize
Signal.with access code
Trunk group used in DISA NO
DISA Secret Code
VG for non-existent No. YES
Routing To Manager NO
Trunk COS 31
Sending of Progress message YES
No. of digits unused (ISDN) 0
B Channel Choice YES
Channels: Attendant Control (Rsvd) 0
Redirection For ACD (Dissuasion) NO
DTO joining NO
Consultation Call On B Channel NO
DID Mode
Automated Attendant NO
Calling party Rights COS 0
Entity Number 10
TS Overflow YES
Number To Be Added
Supervised by Routing NO
Access Cluster ID
VPN Cost Limit for Incom.Calls 0
Immediate Trk Listening if VPNCall YES
VPN TS % 50
CSTA-Monitored NO
Max.% of trunks out CCD 0
Charge Calling And ADN Creation YES
Ratio analog.to ISDN cost
Collect Calls Allowed
Priority of Call
PCM Network Mode
Logical Channel 1__15 & 17__31
TS Distribution on Accesses YES
Use Split Access NO
Heterogeneous Remote Network NO
COS Restrictions - Barring mode Not Restricted / Not barred
ARS Class of service 31
Megacom Service
SDN Service
Quality profile for voice over IP Profile #1
IP Compression Type G 711
Use of volume in system YES
Local Volume (dB)
External Access Server NO
CSTA Tracking MCDU Trk
IE External Forward None
Announcement for dial tone NO
Announcement for Ring tone NO
Private to Public Overflow YES
Trunk group NPD selector
Node arc-vs01
Trunk Groups 20
Public NPD ID 2
Private NPD ID 0
Management Mode Automatic
NPI Unknown NPD ID
NPI Data NPD ID
NPI Telex NPD ID
NPI ISDN Unknown NPD ID
NPI ISDN International NPD ID
NPI ISDN National NPD ID
NPI ISDN Reserved 1 NPD ID
NPI ISDN (User) NPD ID
NPI ISDN Reserved 2 NPD ID
NPI ISDN Reserved 3 NPD ID
NPI ISDN Reserved 4 NPD ID
NPI Private Unknown NPD ID
NPI Private Level 2 NPD ID
NPI Private Level 1 NPD ID
NPI Private PTN Specific 1 NPD ID
NPI Private Local, NPD ID
NPI Private Reserved 1, NPD ID
NPI Private Speed Dial, NPD ID
NPI Private Reserved 2, NPD ID
Public DID transcoding No
lgarner
Re: OmniPCX Enterprise & Exchange 2010
Here is the Phone Features COS that is in use on the phone, it looks fine for me to divert to an external voice mail system, Am I missing anything?
Phone Features COS
Node arc-vs01
Classes of Service 1
Phone Features COS 1
Rights\Prot.against dir.call pickup 0
Rights\Protected against all barge-in 0
Rights\Protected against set barge-in 0
Rights\Outgoing calls only 0
Rights\Forward to external No. 1
Rights\Prot.against multi-l ringing 0
Rights\Protected against forwarding 0
Rights\Protected (against barge-in, etc.) 0
Rights\Prot.against call announc. 0
Rights\Remote wake-up/appointment 1
Rights\Auto call back on busy trk-grp 0
Rights\Transfer on no answer 1
Rights\ISDN remote charge service 1
Rights\Bypass on forwarding 0
Rights\Prot.against bypass onforward 0
Rights\Interphony 1
Rights\Secret Code, Repertory Key 0
Rights\Night Serv.Answ.Pick up 1
Rights\Night Serv.Direct call pick-up 1
Rights\Attendant Call Privil.on PAI 0
Rights\Busy priv.to public overfl. 1
Rights\Server-Minitel PC 0
Rights\Prot.against Priv.Call 0
Rights\Prot.against.Rem.Forward. 0
Rights\Beep On Ext.Call 0
Rights\O/S private to public overflow 1
Rights\Transfer outgoing - incoming 1
Rights\Transfer Outgoing-Outgoing 1
Rights\PCX Calls Follow Ext. forwarding 1
Rights\Mask ID.name Only for ext.calls 1
Rights\Ringing tone In Handset 1
Rights\No Text Msg reception 0
Rights\No Callback On Free Set 0
Rights\No Callback On Busy Set 0
Rights\Override Att Control of TG (Resv) 0
Rights\No Substitution 0
Rights\Reserved or Att Control 0
Rights\Lock Key 0
Rights\Prot.against Guest Private Call 0
Rights\Prot.against VIP Private Call 0
Rights\Prot.against Private Call res1 0
Rights\Prot.against Private Call res2 0
Rights\Prot.against Automatic answer 0
Rights\Authorized DISA unlocking 1
Rights\Timed Call Release 0
Rights\Calling name display (CNIP/I-CNAM) 0
Rights\Int. calls overflow if caller 0
Rights\Int. calls overflow if called 0
Rights\Record Authorization 1
Rights\Casual Conference 1
Rights\Silent Connection on Agent 0
Rights\Virtual set on CMP board 0
Rights\Forward if MIPT/IP out of service 1
Routing Mode At Off-hook NO Routing
Inter-Company Calling Right No
Set features\Immediate forward 1
Set features\Immediate forward on busy 1
Set features\Forward on no answer 1
Set features\Forward on busy or no answer 1
Set features\Forward cancellation 1
Set features\Forward cancel.by destinat. 1
Set features\Overfl.on no answer to associate 1
Set features\Cancel Overfl.to associate 1
Set features\Sta. group exit 1
Set features\Sta. group entry 1
Set features\Protect. against barge-in & beeps 0
Set features\Lock 0
Set features\Auto-assignment 1
Set features\Substitution 1
Set features\Password modification 1
Set features\Accounting/Chargeback Readout 1
Set features\Do not disturb 1
Set features\Set Out/In of Service 1
Set features\Associated Direct. No. modif. 1
Set features\Remote forward 1
Set features\Cancel Remote forward 1
Set features\Unused 1
Set features\Cancel auto. callback on busy 1
Set features\Personal directory Programming 1
Set features\Personal Directory Use 1
Set features\Language 1
Set features\Adjust Display Visibility 1
Set features\Access and Review Alarms 1
Set features\Camp-on Control 0
Set features\Overfl.busy to assoc.set 1
Set features\Overf.busy/no answer to assoc.set 1
Set features\Voice Guide Listening 1
Set features\Suite Do Not Disturb 1
Set features\No Ringing 0
Set features\Tandem: Assistant Away 1
Set features\Tandem: Filter activation 1
Set features\Force Set Type Identification 1
Set features\Privileged substitution 1
Set features\Ubiquity Mobile Programming 1
Set features\Ubiquity 1
Set features\Remote Extension Activation 1
Set features\Remote Extension Deactivation 1
General Services\Group call pickup 1
General Services\Direct call pickup 1
General Services\Processing group call pick up 1
PCX Services\Speed call to associated set 1
PCX Services\Access Callback list 1
PCX Services\Last Caller Callback 1
PCX Services\Paging call answer 1
PCX Services\Voice Mail Access 1
PCX Services\Wake-up/appointment reminder 1
PCX Services\Tone test 1
PCX Services\Collect telex 1
PCX Services\Collect text 1
PCX Services\Collect fax 1
PCX Services\Message deposit 1
PCX Services\Text deposit 1
PCX Services\Image deposit 1
PCX Services\ACD Prefixes 1
PCX Services\Meet-me Conference 0
PCX Services\Cancel Wake-up 1
PCX Services\Switch off Message LED 1
PCX Services\Room status management 1
PCX Services\Mini-bar 1
PCX Services\Voice Mail Manager Access 1
PCX Services\Conversation Recording 1
PCX Services\PCX address in DPNSS 1
PCX Services\Direct Paging Call 1
PCX Services\Infocenter 1
PCX Services\Voice Mail Deposit 1
PCX Services\Select Primary Line 1
PCX Services\Select Secondary Line 1
PCX Services\Z dialing Behind UA 1
PCX Services\Mask remote identity 1
PCX Services\Recordable Voice Guides 1
PCX Services\Suite Wake-up 1
PCX Services\Suite Wake-up Cancel 1
PCX Services\Physical Room Call 1
PCX Services\Under A4980 Control 1
PCX Services\Manual Add-on Conference 0
PCX Services\Automatic Add-on Conference 0
PCX Services\Announcement 0
PCX Services\Automatic Answering 1
PCX Services\Call Restriction Service 0
PCX Services\Explicit Priority 0
PCX Services\Intercom Service Loop 0
PCX Services\Explicit Precedence level 0
PCX Services\CUG Call 1
PCX Services\Background Music 1
External Services\Direct trunk seizure 1
External Services\Business account code 1
External Services\Redial last number 1
External Services\Night service answering 1
External Services\DTMF Frequencies test 1
External Services\Park Call/Retrieve 1
External Services\Waiting call Consultation / Access 1
External Services\Rotary End-to-End Signal. 1
External Services\DTMF End-to-End Signal. 1
External Services\Malicious call 1
External Services\Common Hold 1
External Services\Priority of Call 1
External Services\Secret/Identity 1
External Services\Alphanumeric Paging 1
External Services\Manual Hold 1
Suffixes\Broker Call 1
Suffixes\Three-Party conference 1
Suffixes\Barge-in 0
Suffixes\Callback on free or busy set 1
Suffixes\Camp-on Waiting 1
Suffixes\Speaker Paging 1
Suffixes\Call announce through speaker 1
Suffixes\Consultation Call 1
Suffixes\Paging request 1
Suffixes\Business number 1
Suffixes\Rotary End-to-End Dialing 1
Suffixes\DTMF end-to-end dialing 1
Suffixes\Malicious Call 1
Suffixes\Voice Mail Message Deposit 1
Suffixes\Camp-on Control 1
Suffixes\Voice Mail Access 1
Suffixes\By pass on Do Not Distrub 1
Speed Dialing Area\Area 0 1
Speed Dialing Area\Area 1 1
Speed Dialing Area\Area 2 1
Speed Dialing Area\Area 3 1
Speed Dialing Area\Area 4 1
Speed Dialing Area\Area 5 1
Speed Dialing Area\Area 6 1
Speed Dialing Area\Area 7 1
Speed Dialing Area\Area 8 1
Speed Dialing Area\Area 9 1
Speed Dialing Area\Area 10 1
Speed Dialing Area\Area 11 1
Speed Dialing Area\Area 12 1
Speed Dialing Area\Area 13 1
Speed Dialing Area\Area 14 1
Speed Dialing Area\Area 15 1
Speed Dialing Area\Area 16 1
Speed Dialing Area\Area 17 1
Speed Dialing Area\Area 18 1
Speed Dialing Area\Area 19 1
Speed Dialing Area\Area 20 1
Speed Dialing Area\Area 21 1
Speed Dialing Area\Area 22 1
Speed Dialing Area\Area 23 1
Speed Dialing Area\Area 24 1
Speed Dialing Area\Area 25 1
Speed Dialing Area\Area 26 1
Speed Dialing Area\Area 27 1
Speed Dialing Area\Area 28 1
Speed Dialing Area\Area 29 1
Speed Dialing Area\Area 30 1
Speed Dialing Area\Area 31 1
Voice Mail Forwarding Ring Final Set Mail
Default Overflow Type No forward
Default Overflow Addressee Nothing
Quality profile for voice over IP Profile #2
Download Policy Delayed
Start of download\Hour 20
Start of download\Minute 0
Stop of download\Hour 0
Stop of download\Minute 0
Overflow / Associate noreply timer 0
lgarner
I have traces form the VX1200 box, working with audio and without, but each is about 1500 lines and positing it between [ code ] [ /code ] does not seem to work for it.
Let me know if I should post them
lgarner
So i have fired up wireshark on the exchange box, using their VOIP capture tools I can capture the RTP traffic & sip sessions etc, decode and playback the audio for all calls made to the Exchange UM. For calls from my ip phone to the exchange um that have no audio on the ip phone I can capture and playback the audio fine using wireshark, so exchange is answering fine, sending the traffic back to the VX1200 box, so it could be an issue with the VX1200... any idea's?
Still cannot get the calls to diver to the SIP external voicemail either... oh well, i'll keep trying.
Thanks for your help
Cheers
Laurance
Cheers
Laurance
lgarner
YAY - !!! Fixed the 1st issue.
So here is my explanation of how. Please let me know if my reasoning seems OK and add to it as I'm not exactly sure of why it worked sometimes and not others and I would like to learn more.
Our Exchange Server's IP address is set as 10.8.0.24 255.255.0.0 with 10.8.0.1 as the Gateway.
The PBX has IP settings of 10.35.0.75 255.255.0.0 Gateway of 10.35.0.1.
The Phones are getting an IP from the PBX with 10.35.1.0 255.255.0.0, no gateway
So with RTP after the call is "established" the IP Touch phone will need to be able to talk directly to the exchange server which it could not because it had not gateway set.... something along these lines. The explanation of why it worked sometimes is something to do with half RTP or something like that that i read in earlier forums relating to the PBX been able to work in between but it wasnt sometime and was other times.. There was also a small issue with the 10.35.0.1 gateway it was set as a class c range 255.255.255.0 instead of a class b 255.255.0.0.
So I only have one problem now. When I set the SIP External Voice Mail number as the voicemail dir. no. on my user extension it does not divert. The number is 6690, I can call the number from my ip touch extension 6783 fine, my phone feature COS seems ok, its posted above. Really would like some help with this one.
Cheers
Laurance
Cheers
Laurance
