OXO RCE Features
ehciam
OXO RCE Features
Post by ehciam » 07 May 2019 03:59
Is it possible to perform the following tasks using the OXO RCE:
- Blocking internal calls between some stations unless transfered by the operator
- Blocking stations from making exteral calls directly unless transfered by the operator
- What's the best solution to do accounting and taxation using the OXO RCE
I'm asking if these tasks are possible not how to.
tddupree
Re: OXO RCE Features
Post by tddupree » 19 Jun 2019 17:38
HI there,
If you haven't already gotten your answer, I suggest you try to get more info from your ALE Channel Partner, they should be able to assist you with good insight. If not, let me know and I'll see what I can find out.
Konstantinos.E
Post by Konstantinos.E » 20 Jun 2019 10:30
Hello ,
Blocking internal call … you can use selective diversion.
Blocking external call...you must configure barring tables and traffic sharing category
accounting … 8770 (license needed)
Alca_holic
rkraehen
Post by rkraehen » 28 Jun 2019 09:13
Hi ehciam,
Yes it is possible, for blocking calls between internal sets you might need the "Up to 4 entity" lisense.
For accounting you could use a certified ALE application partner software with the OXO OHL driver (see attachment)
Rg, rkraehen
Return to “Beginner's questions about the OmniPCX OFFICE”
