Config of ISDN to PSTN
freddiem
Post by freddiem »
I have a customer would like to install 130 channel ISDN line to the omnipcx Alcatel Telephone system but I have not configured any. I can only login and configure analogue lines. I have tried to read the manuals but can not get it. Can I be helped on step by step configuration.
I have done the following configurations on the system but I can not both make and receive calls. The numbers that are from the TELCO are in the range 426300 to 426329
I am only able to configure ISDN to NEC SL1000 telephone system. Kindly help.
Alcatel ISDN.pdf
mustafa.ahmad
Re: Config of ISDN to PSTN
Post by mustafa.ahmad »
check the documentation of OXO properly, as it will be difficult to explain one by one step,
and also u will need to manage the ARS for the incoming and outgoing calls.
Return to “Beginner's questions about the OmniPCX OFFICE”
