hello!
i'd like to know how do i can configure a phone 4038 alcatel to work like a switch with a cisco 2960 with two vlan's one for data and the other for voice.
On the switch cisco the port g0/9 is configured like this
switchport access vlan 737
switchport mode access
and the phone works well
if i configure it for data like this
switchport access vlan 700
works well, too.
but if i can use it , the switch , plugging a pc on the phone with this configuraton below
switchport trunk allowed vlan 700,737
switchport voice vlan 737
switchport mode trunk
neither phone works nor the pc.
what is happenning?
Best regards, Thanks
configuring cisco 2960 to work with alcatel 4038
Re: configuring cisco 2960 to work with alcatel 4038
You have to configure the VLAN in the phone. The port configuration (trunk mode) is waiting for tagging packages. I recommend the following configuration: perhpas access mode with a tagged VLAN for IPTouch and a default untagged VLAN for the PC. Best regards.
ACSE R11
OT R2.0
OT R2.0
- torrentula
you will want to use the "voice vlan" command for the vlan you want the 4038 to be on.
Then either hard code vlan on the phone using the LUI, or use AVA.
you have 3 possibilities:
1) both devices in the same vlan -> not advisable
2) using the voice vlan which is an cisco feature/behaivor
example:
interface gigabitEthernet 0/38
switchport access vlan 700 #PC VLAN
switchport voice vlan 737 #Phone VLAN which is tagged
verify the setting
cat2#show interface gig 0/38 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate # port can negotiate as trunk if possible
Operational Trunking Encapsulation: native # no trunking currently
Negotiation of Trunking: Off
Access Mode VLAN: 700 (VLAN0700) # Access Vlan ID (untagged)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 737 (VLAN0737) # Tagged voice vlan
*** Deleted rest of output
You have to configure the Phone for using the tagged Vlan ID 737.
3) configure the port as trunk
switchport trunk encapsulation dot1q # to ensure 802.1q tagging
switchport trunk native vlan 700 # defines the untagged vlan
verify the port:
show interfaces gigabitEthernet 0/38 switchport
Hope this help
example:
verify the setting
Switchport: Enabled
verify the port:
Hope this help
