I'm currently having the problem, that I can't telnet my 4038EE in industrial mode via telnet to reset it.
I followed this guide
Everythink works fine until step 4. I simply get a timeout error message that telnet can't connect to 192.168.1.1In industrial mode, the set will only work in a specific sub network, and
default IP address
- IpTouch IP address: 192.168.1.1
- tftp address: 192.168.1.6
You don't have to configure anything on the set, the address above are the
default "industrial" addresses
1)So, on your side you have at first to configure your PC with address "
192.168.1.6"
2)Then start your IpTouch in industrial mode:
- IP Touch starts in industrial mode thanks to key (i 1 2 3)
+ Disconnect power of the set
+ push key i
+ reconnect power (hold always key "i" pressed)
+ push at the same time "1" "2" "3" (and "i" of course)
+ when the leds go on, you can release the key
+ now, the set is in "industrial mode"
3)Use a crossed cable to connect your Set to the PC, or a HUB
4)Now you make a telnet on the set
5) Erase Thales Security
thalsec reset
6) Restart the set
I tried to connect to the phone directly via crossover cable, via regular ethernet cable and via a switch. Nothing has worked.
Does anyone have an idea how to solve this problem.
Thanks in advance,
Tobias
